Intel Wireless Adapter (wifi6) compability
KarthickRaja23
Need a clarification whether we will face any compatibility / connectivity issues while using wifi6 adapter in windows machine while connecting to 2700 and 2800 AP's.
Leo Laohoo
No, there are no issues.
NOTE:  Make sure to update the firmware of the AX200.
Note that 2700 and 2800 APs are not Wi-Fi 6 capable!
But you do need to update drivers for some Intel adapters before they'll work at all with any Wi-Fi 6 (802.11ax) capable AP even though the adapter itself doesn't support 802.11ax.
https://www.intel.co.uk/content/www/uk/en/support/articles/000054799/network-and-i-o/wireless.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Gastu
Frequent Visitor
Frequent Visitor
2700 and 2800 is WIFI5 compatible only. if you need wifi6 you better go for 9100 series AP. despite, your windows adapter should be cross compatible with 80.11a protocol. please check the widows card manufacturer technical document.
good luck ! Hadnet
Question from the OPs is if the 2700/2800 are compatible with WiFi 6 (802.11ax) in which I answered yes.
Had the OPs' question be if the 2700/2800 are 802.11ax capable, my answer would be no.
