Intermittent dropouts Intel Centrino Advanced-N 6205
chris.brunt
We are having big problems just with this particular adapter in our environment. We are getting intermittent dropouts. The connection will freeze and stop responding to the point where you have to do a windows repair or restart the adapter to get it working again. You can be connected for a whole day with no issues or it could happen at random eg after 20 mins of being connected. Other devices in close proximity e.g. an intel 5100 and 5300 agn are working perfectly.
You get no indication that the connection has dropped and the adapter in the systray looks as if it is still transmitting packets but not recieving any. Cisco WCS troubleshoot indicates no problems. Events in the debug stop and dont start again until you do a repair on the machine.
Intel and Lenovo support have been really unhelpful (they basically don't want to know, apalling service), so now i am turning to Cisco just in case its a configuration issue, which i don't believe it is as we have no reported issues at all with other clients.
On the machine sides we have:
Lenovo x220 Tablet with Intel Centrino Advanced-N 6205 mini pci-e adapter.
Also happening with Fujitsu T730 tablets also with with Intel Centrino Advanced-N 6205 mini pci-e adapters
We have tried all intel driver versions from the latest 14.2.0.10 down to the OEM versions supplied.
they are running Windows XP SP3. We have also tried it with Windows 7 and get similar issues.
We are using Windows Wireless Zero Configuration, WPA2-AES with PEAP and machine (computer) authentication against Cisco ACS v5.2 talking to AD.
On the Wireless infrastructure side we have:
Cisco 1142N (-E-K9) APs connected to 3750G w/poe stacks
The controller is a 3750G-24-WS-50 model running version 7.0.116.0
managed by WCS.
The wireless has 20mhz channels on 1,6,11 on the 2.4ghz side (N is disabled) but we do have N enabled with 40mhz channels on the 5ghz with all UK country channels.
The machines connect at up to 300mb/s and signal quality is excellent. AP density is quite high in the room. DCA, TPC and Tx power control are enabled and set to automatic.
Can't think of more detail to include but I would appreciate any ideas anyone may have.
Hi All,
I wanted to shed some light on this topic. We are aware of an issue with connection dropouts on the Intel 6205 specifically. The issue will be resolved in the 15.1 Intel drivers. The root cause has to do with a failure to ack a packet when Infrastructure MFP is enabled, so the current workaround is to disable infrastructure MFP.
If you can, please try disabling Infrastructure MFP and test the client connectivity.
-config wps mfp infrastructure disable
-Pat
67 Replies 67
Stephen Rodriguez
Are you able to do a wireless sniffer trace to see if the client is truly not sending data, or the ap is just dropping it?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
With wireshark i can see packets going to the adapter but they get no response.
Scott Fella
So it only happens with this wlan ssid?  Can you post the show wlan
-Scott
(Cisco Controller) >show wlan 5
WLAN Identifier.................................. 5
Profile Name..................................... SSID vlan 6
Network Name (SSID).............................. SSID
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 1
Exclusionlist.................................... Disabled
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ vlan6
Multicast Interface.............................. Not Configured
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 192.168.1.170 1812
   Authentication................................ 192.168.14.7 1812
   Accounting.................................... 192.168.1.170 1813
   Accounting.................................... 192.168.14.7 1813
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
CCKM tsf Tolerance............................... 1000
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Local Authentication................... Disabled
   H-REAP Learn IP Address....................... Enabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Enabled
Load Balancing................................... Enabled
Mobility Anchor List
WLAN ID     IP Address            Status
Disable the client load balancing and band select.  If that fixes your issue then try to enable band select, but don't enable load balancing.  Leave both off for a couple days and then try to enable band select only...... If you have issue with band select, then you know that you have to disable that too.
-Scott
Thanks for the suggestion. I will give that a go on monday and report back.
That load balancing had caused me headaches! Many of the Apple devices will not connect with this enabled also.
Scott Fella
Sent from my iPhone
-Scott
I have the exact same scenario with the AD/ACS authentication and using WLC and WCS to manage the wirleless network.  The problem only occurs with the newer Intel Centrino Advanced-N 6205 as the bit older Advanced 6200-N does not have the problems.
My current configuration for the two SSID's that the client attaches to does not have the Client load balancing or band select enabled.
Any success with your changes?
I am waiting for feedback on the changes (disabled load balancing and band select on monday) at the moment.
mike.willing
I've been have this exact issue with the following infrastructure:
Cisco 5508 running 7.1.91.0
Cisco 3602i (A)
Here is my current configuration.
(Cisco Controller) >show wlan 20
WLAN Identifier.................................. 20
Profile Name..................................... Data_Laptop_Devices
Network Name (SSID).............................. wland1
Broadcast SSID................................... Disabled
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
Interface........................................ management
Scan Defer Priority.............................. 5,6
Wired Protocol................................... 802.1P (Tag=3)
Passive Client Feature........................... Disabled
Radio Policy..................................... 802.11a only
Radius Servers
   Authentication................................ 10.240.85.171 1812
   Authentication................................ 10.240.85.172 1812
   Accounting.................................... 10.240.85.171 1813
   Accounting.................................... 10.240.85.172 1813
Security
      Auth Key Management
         CCKM.................................... Enabled
   H-REAP Local Switching........................ Enabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Any thoughts or suggest would be appreciated.
Try to set the wireless policy to all first. Then after that test I would disable 2.4 on the client and then set the SSID to 802.11a only and see if that works.
Scott Fella
Sent from my iPhone
-Scott
I have disabled n and 802.11a before on the client with no difference but can't do it on the ssid as we have b/g only devices that connect.
You have this on your ssid:
So how is your clients using the 2.4ghz?
-Scott
Mikes is set to a only my radio policy is set to all see my post further up.
