IP Address on Wireless AP
Rolitto
Level 2
Level 2
Hello everyone,
I am configuring a Cisco wireless AP and the IP address used to access the device is, let's say 192.168.1.1. I know that this wireless AP is a layer 2 device and that this IP address is used to access and manage the device, but my question is:
How is it possible to access the web-based setup page of this device (http://192.168.1.1) via either the wireless interface or Ethernet interface? Does it mean these two interfaces are bridged?
The reason why I am asking is because as far as I know, the IP address assigned by default to a wireless AP is similar to an IP address we assign to a switch when we want to trace and manage it on a network or VLAN, which is interface-VLAN x or SVI x in this case. Am I right or is there anything I am missing here?
Any clarification is appreciated and I would love to hear your opinions as well on this matter, thanks.
Jaderson Pessoa
@Rolitto Hello
Look it:
Before You Start
Before you install the wireless device, make sure you are using a computer connected to the same network as the wireless device, and obtain the following information from your network administrator:
  • A system name for the wireless device
  • The case-sensitive wireless service set identifier (SSID) for your radio network
  • If not connected to a DHCP server, a unique IP address for the wireless device (such as 172.17.255.115)
  • If the wireless device is not on the same subnet as your PC, a default gateway address and subnet mask
  • A Simple Network Management Protocol (SNMP) community name and the SNMP file attribute (if SNMP is in use)
  • If you use IPSU to find the wireless device IP address, the access point MAC address. The MAC address can be found on the label on the bottom of the access point (such as 00164625854c)."
But this can be changed according ap's model.
Look here for more information: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html
Look here config it trough GUI: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap2-gui.html#64205
Jaderson Pessoa
*** Rate All Helpful Responses ***
5 Replies 5
Scott Fella
What wireless. Ap model and image?
-Scott
Cisco WAP121.
Mark Elsen
 - Well if you need to still configure it , there will be no valid wireless configuration , including SSID's and functional radio's, so you are limited to access via Ethernet.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Jaderson Pessoa
@Rolitto Hello
Look it:
Before You Start
Jaderson Pessoa
I will configure it using CLI.
