Client in same WLAN cannot ping eachother
CSCO11395771
Community Member
WiFi clients in same WLAN(ssid) cannot ping eachother.
AP's are in Flexconnect mode, WiFi clients are able to access network and internet etc, but not able to ping eachother.
whereas, Lan devices from same network are able to ping these wifi client.
There is no firewall or ACL as such in WLC or local switch. Also Peer-to-Peer blocking is 'disabled'.
Also i'm able to see client arp entries in WLC and local switch.
What could be causing this issue, and how can we resolve this?
Pls comment.
Moin Ilyas
Level 8
Level 8
Did you check if WiFi clients are able to ping LAN Devices on the same network or not?
Yes, even WiFi clients are able to ping LAN devices, and vice-versa.
wreed_cisco
Community Member
Did you ever fix this? I am having the same issues.
DISABLE Public Secure Packet Forwarding on the radio interface in play
