Ip unicast and multicast when using switch based wds
solomonthuo
Level 2
Level 2
hi
Am trying to configure my first SWAN and am getting some problems in grasping the necessary configs for enabling multicast. I am deploying 30 access points and each needs five mobility groups in which downstream multicast traffic is needed. I am thinking of creating a subnet that can support the 30 IPs for the access points and the 1 layer 3 address for the multicast VLAN on first hop router ( actually the links terminate on 6509 switch). I don't really understand how to do these configs for multicast part but i understand fully on how configure the other stuff
regards solomon
smalkeric
Level 11
Level 11
Do a configuration push between subnets/over routers and some switches. To do that do a config dump and loading through the device you want to load the config to. If the equipment is all on the same subnet, then setting one of your units to default then only adding in the MAC address filters and trying to push it. If it still unable to push the MAC address filters, you may end up having to temporarily having to do config pulls rather than pushes
