IR809G Check Signal strength?
K-Grev
Hi, does anyone know of a way to remotely check statuses of signal strength on an IR809G Cellular Router?
K-Grev
For anyone curious.
#Show cellular <0-1> all
or
#show cellular <0-1> ? will show sections from the "All" command.
K-Grev
For anyone curious.
or
Rich R
Have you tried "show cell 0 radio" as per https://www.cisco.com/c/en/us/td/docs/routers/access/800/829/software/configuration/guide/b_IR800config/b_cellular.html ?
