Is it a good thing that 2.4GHz transmit power outperforms 5GHz?
RezaFH
Hi all,
As stated in the title, I'm now investigating a situation where the client prefers the 2.4GHz band channel over the 5GHz band channel. After i'm seeing the on the transmit power configuration
2.4GHz power level 1/8 (22 dBm)
5GHz power level 1/8 (18dBm)
even after enabling band select, the client still prefers 2.4GHz
because i want the client to prefer 5GHz without changes on the client side or i needed to create new SSID for 5GHz only
Additional Info
currently using 9800 WLC & 9210 Access Point
please advice
 Yes, I think it is a good idea control 2.4 power.  That´s something I usually do. I prefer let 5.0gz explore all the available power and 2.4ghz no more then 10 (-10 to 30 availablr).  But, dont simply follow the number I gave. Each environment have different requirements.
  The best way is control the power and observe.
You can also turn band select into a more aggressive mode by playing with Cycle Threshold and Cyple Count. But, again, find you own values.
6 Replies 6
balaji.bandi
Create a AP group and disable 2.4GH on that AP group and test it.
BB
Hi Balaj,
Thanks for the input
i have tried that and the client connect to the 5GHz, but i dont wanna disable the 2.4
Thanks for the input, i'm gonna try that on lab with condition on open space and closed space
Leo Laohoo
What is the wireless client's network card?
it's intel Wi-Fi 6 AX201, driver version 22.120.1.9
