It needs to change Flex mode to local mode?
Leftz
Level 4
Level 4
Hi AP3800 in Flex mode is connected to wlc 5520. If we want to connect the AP to C9800, do we need to change Flex to local mode? Thank you
2 Accepted Solutions
 It does not matter.  The AP in flexconnect mode or local mode will performs the same process to find and join the WLC. Only after the AP joins the the WLC is that flexconnect or local mode will be important.
You need to check but probably in local mode. The AP will change the code and get new information from the WLC.  It is a totally
new WLC.
You must see this on the new WLC:
Leftz
Level 4
Level 4
@Flavio Miranda  Thank you very much for your reply. but after ap join c9800, what mode the ap looks like when we see the ap via gui?
new WLC.
Leftz
Level 4
Level 4
Great! Thanks
