Is it possible to configure Open mode at wlc C9800
Leftz
Level 4
Level 4
Hi WLC c9800 is configured with 802.1x and via ISE. We know we can configure Open mode at switch for 802.1x /ISE. Is it possible to configure Open mode at C9800? Thank you
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213919-configure-802-1x-authentication-on-catal.html#anc8
   Except in Step 3 choose :
  •  None—No Layer 2 security.
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Tony Rosolek
I'm not aware of such option on the WLC. Maybe there is an option directly on the ISE, that it configures it to (blindly) accept all clients. The ISE controls the access and the WLC is just doing what the ISE tells it to do.
With WPA2-Enterprise SSIDs encryption keys are negotiated between ISE and client. These keys are needed for encryption. Or instead of WPA2-Enterprise you use a completely open and unencrypted SSID.
||| Please rate helpful posts. Thanks! |||
Leftz
Level 4
Level 4
Thank you for your reply. I also doubt there is the option in WLC. We can use No layer 2 security or psk, but it totally by pass ISE, so that we would not know status of ISE
