Is there an example of wlc 5520 cpu acl?
CCC3
I'm trying to set up a CPU ACL on the WLC 5520.
Do you have any examples?
For example, I gave 10.10.10.10/32
I don't know, but 10.10.10.11/32 is also login wlc, so I'm looking for a problem.
Do I have to set both inbound and outbound in both directions when I set up acl?
marce1000
  - FYI https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/71978-acl-wlc.html
     Take care when working on CPU ACL's on a controller that is in production ; don't lock yourself out!
 M.
I've already checked the document in the link you gave me, but I don't have enough information. Even non-permit ip can be accessed, and when connected with permit ip, it can be counted in deny..
Hard to say what you've done wrong without seeing the ACL but sounds like you might have made a mistake in some of the entries.
Is the ACL actually applied to CPU?
Yes
