Is there any difference among AP9130AXI -A, -B, or C etc?
Leftz
Level 4
Level 4
Is there any difference among AP9130AXI  such as C9130AXI-A, -B, or C etc. What does that mean? or what is difference between them? Do we have a link for it? Thank you
2 Accepted Solutions
Yes, -B is correct regulatory domain for USA. The part number should be C9130AXI-B.
Leftz
Level 4
Level 4
Thank you very much!
-A, -B etc represents country codes. Basically you need to select the AP part number based on the country the AP will be installed. Use the following WLAN Compliance tool to select the correct AP Part number.
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
CJ
/** Please rate useful responses **/
Leftz
Level 4
Level 4
Thank you for your reply. I got the below info. So the product number is "Regulatory Domain"? we are in USA, so we need to buy C9130AXI-B?
Leftz
Level 4
Level 4
