issue adding adder license to 2504 Wlc
huber
Level 2
Level 2
I have ordered an additional 5 licenses for a 2504 wlc. I also registered it with Pak key all worked fine but i can not get it to work.
When i upload it from tftp it tells me it that it is allready installed.
I have then tried to activate the eval license remove the base license and uploaded the new one from tftp. But still 5 license not the 10 i would expect in total.
Any idea what i did wrong?
5 Replies 5
Stephen Rodriguez
reboot the WLC, and then check the licensing again.  If it's still not there, then attempt the uploade
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Steve
I have reloaded the WlC and still the same picture, only 5 license instead of the 10. i tried it on 7.2 and 7.3 code but same behaviour
open the license with wordpad, and see if it says 10 or 5 AP.  When you registered the PAK adn SN of the WLC, it should have created the one license with 10 AP total.  The 5 new, and the 5 original.
if it doesn't show 10 you'll want to get a case open with the Licensing team to get it fixed.
HTH,
Steve
HTH,
Steve
Thanks, did do that as well. License tells me 10. thats why i find it odd after deleting the license and adding it new still having only 5
Hi all
Solution was to open TAC case. The engineer issued a new cert file which then worked.
Raz
