Issue connecting 1131AG - Regulatory domain check has failed for the AP
f-foster
I have 2 1131AG LWAPP AP's purchased in the UK connecting to a WLC 5508 in the US that is setup only for Country US.  I am getting the above error when trying to add Country GB United Kingdon I get an error that 802.11b and 802.11a are enabled and must be disabled to use this country code.  I am not sure if there is a workaround for this because I do not want to disable these networks.
Scott Fella
Well you need to disable them temporarily to allow you to set the other country code.  Once set, you can enable the 802.11a and 802.11b radios globally again.
-Scott
download wlc configuration guide again. and see index global mode.
Sandeep Choudhary
Here is the method to change country code:
GUI:
Step 1 Follow these steps to disable the 802.11a and 802.11b/g networks as follows:
a.          Choose Wireless> 802.11a/n > Network.
b.          Unselect the 802.11a Network Status check box.
c.          Click Apply to commit your changes.
d.          Choose Wireless > 802.11b/g/n > Network.
e.          Unselect the 802.11b/g Network Status check box.
f.          Click Apply to commit your changes.
Step 2 Choose Wireless > Country to open the Country page
Step 3 Select the check box for each country where your access points are installed. If you selected more than one check box, a message appears indicating that RRM channels and power levels are limited to common channels and power levels.
Step 4 Click OK to continue or Cancel to cancel the operation.
Step 5 Click Apply to commit your changes.
Step 6  Reenable the 802.11a and 802.11b/g networks
By CLI:
Before you can change the country code of a WLC, you must disable the 802.11a and 802.11b network :
>config 802.11a disable network
>config 802.11b disable network
Now you can change the country code of the controller. For example, we change it from US to IN (INDIA)
>config country GB
After changing the country,enable the 802.11 interfaces.
>config 802.11a enable network
>config 802.11b enable network
Dont forget to rate helpful posts.
world mode wlc configuration join controller.. contact with cisco TAC engineering call 18005532447. TAC team help you within minute.
