Issue connecting to wireless printer at specific time
Hi Experts ,
I have one issue to troubleshoot wireless printer device.
Issue is :
One user is unable to give the print every monday at 5:00am-5:15am CET .So during this time the printer device goes unreachable from the source .Means ping from Source server to printer/scanner devices times out . This is the wireless printer associated with AP (cisco AIR-CAP2702E-E-K9).
I know the IP and MAC address of the printer device .Can someone help me with the steps to investigate this issue from Network side .and also help me with the command which I can execute on the WLC cli.
This printer may be the device used in billing .So at 5am this is the only guy available may be .So we do not have information whether other use it . But issue occurs at every Monday at 5am cet .
5 Replies 5
Scott Fella
Are any other users able to print?  Is this wireless printer going to sleep and not waking up?  There is no reason that you wouldn't be able to print during a certain time.  Seems like someone might be coming in a rebooting the printer or doing something so that it starts working at 5:15?  Seems like you need to investigate more, maybe have them reboot the printer in the morning, but that is up to you and what your troubleshooting leads you to.
-Scott
I am going to check this live on coming Monday ..Incase if no manual intervension is done at this time then from Network side what all checks we can do to isolate this issue ?
May be I can do ping client Ip from WLC and see if its reachable nd check show logging and filter client MAC/IP and see what error logs I get .
I think you need to possibly work with the person and actually see what he/she is doing.  What I'm curios of, is what changes after 5:15 that makes it work, or is that something that they say and not really fact.  You should also check to see if the users device is a wired machine or a laptop which he/she brings home.  I have had similar complaints connecting to a network when the use comes in, and its because they don't shut down and just close their laptop lid and come to the office.  Their laptop doesn't try to refresh the ip address unless the device is refreshed, manual ip renew or after 10 minutes, the laptop refreshes the ip address.
-Scott
Leo Laohoo
Turn the printer's DST settings on (so the printer goes +1 hour) and see if the issue follows the printer's time.
Rich R
And you should also consider the old cleaner story we've all heard before:
Does the cleaner come in and unplug the printer to plug in the vacuum cleaner every day/week at the same time?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
