Issue connecting Windows 10 Client to network using WPA3
user2022
Hi all,
1. I have using C9130AXI-D as EWC and have set Wireless network as WPA3-enterpsie along with GCMP256. I have configured setting on both EWC and Windows 10 client as given in
https://mrncciew.com/2020/08/17/wpa3-enterprise/
2. The configurations were set without error. But when a try to connect to AP I get a message on Windows " Can't connect to this network". I am attaching the log snapshot of EWC for reference. Please help me out.
30 Replies 30
Mark Elsen
 - What is in  the Event Log (eventvwr) , when this happens  ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I am getting these logs
WLAN AutoConfig service failed to connect to a wireless network.
Network Adapter: Intel(R) Wi-Fi 6 AX201 160MHz
Interface GUID: {28b3899e-fb4e-4899-9bf2-5c0771a73990}
Connection Mode: Manual connection with a profile
Profile Name: CWN
SSID: CWN
BSS Type: Infrastructure
Failure Reason:The specific network is not available.
RSSI: 255
But the network SSID is available
 - FYIhttps://community.intel.com/t5/Wireless/WPA2-Enterprise-unable-to-connect-in-Windows-10-version-2004/m-p/1204484
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for reply. I am able to connect successfully using WPA2-enterprise using same hardware and software.Also I am using Intel AX210 with drivers 22.60.0
Scrutinize the complete article and details. M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for the reference. I have studied the complete thread and downloaded latest dev version of Windows 10. But I get same result
SettingsSettings
event on windows 10event on windows 10
ssid seenssid seen
 - Could you try another/lower  encryption type (not GCMP256) on both C9130AXI-D  and the windows client.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Windows Client only supports GCMP256
                                        >...Windows Client only supports GCMP256
 - Further actions may include , using a client which can do the lower ciphers (as a test) , 2)  have a full radioactive trace (client debugging) on the controller and last not least engage with cisco TAC.
              https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213949-wireless-debugging-and-log-collection-on.html
                       Presumably a number of features described in the above document may be available on the C9130AXI-D with EWC too.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Which software release is running on the AP? Maybe you're running into a bug.
This is current, very good. In this case please create the radioactive trace as outlined by marce1000.
I am attaching the full radioactive trace. Please see if you help me with it
https://drive.google.com/file/d/17oG-coSZ0PsoC8Nb0OJQ-rDSDn6F7FLy/view?usp=sharing
 - Seems this file is not accessible for the general public , I got :
                        Google drive
                     You need access
               Ask for access, or switch to an account with access.
           Ask for access, or switch to an account with access. Learn more
 M.
       Beauty and terror
      Just keep going
       No feeling is final
