issues activating 5ghz on 3702e in autonomous mode
alienkidmj12
Hi people,
Im a student learning about cisco equipment, i bought a couple of cisco 3702e and a 3702i waps to
have a play around with, ive ran into an issue where i cannot for the life of me get the 5ghz
part working, it just refuses to work, ive tried the gui and it shows a red arrow going down
even though i have 'no shutdown' enabled. The 2.4ghz works flawlessly at 130mbps.
Ive seen info online around priming, and im not sure if these models require that ? if so im a bit snookered without a support account. i have looked at it, but the android app is to be honest is a bit flakey.
thanks
dave
bifrost-cisco3702e-REAR#show version
Cisco IOS Software, C3700 Software (AP3G2-K9W7-M), Version 15.3(3)JPJ4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Wed 29-Jul-20 01:43 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
bifrost-cisco3702e-REAR uptime is 5 minutes
System restarted at 17:01:58 GMT Sun Jan 31 2021
System image file is "flash:/ap3g2-k9w7-mx.153-3.JPJ4/ap3g2-k9w7-xx.153-3.JPJ4"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP3702E-B-K9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FJC2203M2PG
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: B0:26:80:9D:BD:18
Part Number : 73-15397-02
PCB Serial Number : FOC21506DPT
Top Assembly Part Number : 068-05055-08
Top Assembly Serial Number : FJC2203M2PG
Top Revision Number : A0
Product/Model Number : AIR-CAP3702E-B-K9
Configuration register is 0xF
bifrost-cisco3702e-REAR#show running-config
Building configuration...
Current configuration : 3469 bytes
! No configuration change since last restart
version 15.3
no service pad
service password-encryption
hostname bifrost-cisco3702e-REAR
logging rate-limit console 9
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
clock timezone GMT 0 0
no ip source-route
ip routing
ip cef
ip domain name bifrost.co.uk
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 192.168.0.42
dot11 mbssid
dot11 pause-time 100
dot11 syslog
dot11 ssid bifrost-sivesd_and_nobblee
vlan 2
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxxxxxxxx
dot11 ssid bifrost-utilities
vlan 1
authentication open
mbssid guest-mode
wpa-psk ascii 7 xxxxxxxxxxxxxxxxxxx
no ipv6 cef
username Cisco password 7 xxxxxxxxxxx
username sivesrutherfordd privilege 15 secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
description 802.11 2.4GHz bgn
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
antenna gain 0
stbc
speed basic-12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel 2412
station-role root
rts threshold 2312
world-mode dot11d country-code GB both
interface Dot11Radio0.1
description VLAN for SSID bifrost-utilities
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
description 802.11 5GHz a n
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm tkip
antenna gain 0
peakdetect
no dfs band block
stbc
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. a1ssnone a2ssnone a3ssnone
channel dfs
station-role root
interface Dot11Radio1.2
description VLAN for SSID bifrost-sivesd_and_nobblee
no ip route-cache
no cdp enable
bridge-group 1
interface GigabitEthernet0
no ip address
duplex full
speed 1000
bridge-group 1
interface BVI1
mac-address b026.809d.bd18
ip address 192.168.0.105 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip route 0.0.0.0 0.0.0.0 192.168.0.100
ip ssh version 2
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^CCCCCCCC
* Unauthorized access prohibited
* You are connected to CISCO 3702e Access Point* at ip 192.168.0.105
^C
line con 0
line vty 0 4
exec-timeout 0 0
privilege level 15
login local
length 0
transport input ssh
sntp server uk.pool.ntp.org
end
12 Replies 12
Scott Fella
Well your ap's have the new US code and I see you are configuring "world-mode dot11d country-code GB both".  Start with the basic and remove this.  Also keep in mind that you don't want to use tkip, so I would also remove that.  Also set a channel so you can test.
config t
no encryption vlan 2 mode ciphers aes-ccm tkip
channel 36
-Scott
ok, ive made these changes,
scanned for 5ghz on mobile, nothing showing yet.
no ip address
no ip route-cache
antenna gain 0
peakdetect
no dfs band block
stbc
channel 5180
station-role root
no ip route-cache
no cdp enable
bridge-group 1
Leo Laohoo
The AP is a 3702E.  What antenna are installed?
ive tried all 4 standard, i also tried removing 2 of the standard ones and putting longer ariels.
do these not require priming ? as i asked that question earlier, i didnt get a response.
dave
3702E antenna must be dual band.  Maybe you're using a single-band antenna?
antennas are antennas, nothing much to them, not sure the wap would know any difference, they are bi-directional antennas, the standard supplied ones, they are metal and plastic inside, no electronics or anything, just standard n-type connector antennas.
the web gui doesnt even show that the 5ghz is enabled, on all 3 wap's , i have a hard time believing its the antenna's . the 3702i doesnt even have external antennas, so that cant be the issue there.
actually no, there are single band and dual band antenna models which look almost identical but just have slightly different markings or coloured band so it matters which you are using.  That said that won't stop your interface coming up on IOS - just the radio performance of the AP.
No, the universal AP models came with country code UX in the part number.  Yours is -B (North America).  Note that it is illegal to use that AP in UK/Europe ...
Only significant difference I can see from my working 3702E (apart from country code) is that you should be using DFS for channel selection.  While 36/5180 (U-NII-1) does not require DFS all the higher channels do so just stick to standards and use "channel dfs".  Because you're using a -B AP you may need to block out the US channels which are not allowed in Europe check
https://en.wikipedia.org/wiki/List_of_WLAN_channels#5_GHz_or_5.9_GHz_(802.11a/h/j/n/ac/ax)
and
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/atnms-ap-8x/configuration/guide/cg-book/cg-chap6-radio.html
If it still isn't working power it on and log everything (entire boot process) on the console to a text file and attach in your reply.  Also attach a "show controller dot11 1" and "show int dot11 1"
Output as requested, ive also since done 'dfs band 4 block' on dotradio1
bifrost-cisco3702e-REAR#show controller dot11 1
Radio BR 5GHz, Base Address b026.80a1.16b0, BBlock version 0.00, Software versio n 4.18.2
Serial number: FOC22012FRM
Unused dynamic SQRAM memory: 0x0001F3A8 (124 KB)
Unused dynamic SDRAM memory: 0x00319040 (3172 KB)
Spectrum FW version: 1.15.4
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: Americas (OFDM) (US) (-B)
Uniform Spreading Required: Yes
Configured Frequency: 0 MHz Channel 0
Serving Frequency: 0 MHz Channel 0 20MHz
Allowed Frequencies: * Dynamic Frequency Selection (DFS) only
5180( 36) 5200( 40) 5220( 44) 5240( 48) *5260( 52) *5280( 56) *5300( 60) *5320( 64) *5500(100) *5520(104)
*5540(108) *5560(112) *5580(116) *5600(120) *5620(124) *5640(128) *5660( 132) *5680(136) *5700(140) *5720(144)
5745(149) 5765(153) 5785(157) 5805(161) 5825(165)
Listen Frequencies:
5180( 36) 5200( 40) 5220( 44) 5240( 48) 5260( 52) 5280( 56) 5300( 60) 5320( 64) 5500(100) 5520(104)
5540(108) 5560(112) 5580(116) 5600(120) 5620(124) 5640(128) 5660( 132) 5680(136) 5700(140) 5720(144)
DFS Blocked Frequencies: none
Beacon Flags: 0, Interface Flags 20109, Interface Events 0, Mode 9; Beacons are disabled; Probes are disabled
Configured TxPower: 17 dBm (Level Index 1)
Allowed Power Levels: 17 14 11 8 5 2 dBm
Allowed Client Power Levels: 17 14 11 8 5 2 dBm
Antenna: Rx[]
Tx[a b c d ofdm all]
External
Gain [Allowed 12, In Use 12] (dBi x 2), In Use 12] (dBi x 2), In Use 12] (dBi x 2), In Use 12] (dBi x 2), Reported 8, Configured 0, In Use 12] (dBi x 2)
Active Rates:
Current Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2
Allowed Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates: 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
Default Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
Best Range Rates: basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
Best Throughput Rates: basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0-2 m1-2 m2-2 m3-2 m4-2 m5-2 m6-2 m7-2 m8-2 m9-2 m10-2 m11-2 m12-2 m13-2 m14-2 m15-2 m16-2 m17-2 m18-2 m19-2 m20-2 m21-2 m22-2 m23-2 a0.1-2 a1.1-2 a2.1-2 a3.1-2 a4.1-2 a5.1-2 a6.1-2 a7.1-2 a8.1-2 a9.1-4 a0.2-2 a1.2-2 a2.2-2 a3.2-2 a4.2-2 a5.2-2 a6.2-2 a7.2-2 a8.2-2 a9.2-4 a0.3-2 a1.3-2 a2.3-2 a3.3-2 a4.3-2 a5.3-2 a6.3-2 a7.3-2 a8.3-2 a9.3-2
Current Voice Rates: basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
Default Voice Rates: basic-6.0 basic-12.0 basic-24.0
Active Voice Rates:
Managment Rates:
Multicast Rates:
Multicast Active rate: 0.0
RTS Rates:
RTS Active rate 0.0
RTS Max rate 0.0
Local Packet Rate Probing is disabled : Packet Size 20
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 6.0, 15, -89) ( 9.0, 16, -88) (12.0, 18, -88) (18.0, 19, -86)
(24.0, 20, -85) (36.0, 24, -81) (48.0, 27, -78) (54.0, 31, -77)
CVBF: Enabled in IOS, radio FW bfmr flags 0x0 (enabled)
Number of MFP Indices: 10
Driver tx timeout:60
QOS Tag Status: disabled
AuthIEEnabled DS: 0
AuthEnabled reg: 0
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
GAS Req limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular 0x9, Mode 1, Disabled
ELM Disabled, Host State:Off Promiscuous Mode dwelling 0 %
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP **bleep** Stats: STA MIC-L-Errs MIC-R-Errs Replay C-Measure
0000.0000.0000 00000000 00000000 00000000 00000000
AES-CCMP **bleep** Stats: 00000000 replays discarded
Channel Utilization Extensions: Disabled
SMPS Mode: Enabled
QBSS Load: 0x0 Tx 0 Rx 0 AP 0
EDCA Turbo Off Thresholds 60 10 4, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6 0, tx_on_up4 0
Configured Local Access Class Parameters
Back : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
Best : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Local Custom Access Class Parameters
Best : cw-min 1 cw-max 2 fixed-slot 1 admission-control Off txop 0
Configured Cell Access Class Parameters
Best : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
Video : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
Voice : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,downlink classified_pkt 0,uplink classified_pkt 0,num_processed_SIP_Calls 0
BA Info: Lost List Count: 0 Head:0
Off Channel Rdy 0 Done 0 0 0
Transmit queues: Limit 27839 Current 0 In-Progress 0 ACQ inserts 247 deletes 247 reins 0
---- Active ------ In-Progress --------------- Counts --------------
Cnt Quo Bas Max Cl Cnt Quo Bas Sent Discard Fail Retry Multi
Uplink 0 64 0 0 0 0 0 0 0 0 0 0 0
Voice 0 512 0 0 0 0 0 0 0 0 0 0 0
Video 0 1024 0 0 0 0 0 0 0 0 0 0 0
Best 0 1024 0 0 0 0 0 0 0 0 0 0 0
Back 0 128 0 0 0 0 0 0 0 0 0 0 0
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq Vlan
Driver TX blocks: Realign - 0
Off Channel Stats: Last Duration 0, Errors: Timeouts 0 Tx 0 Intr 0
---Clients 0 AID VLAN Status:S/I/B/A Age TxQ-R(A) Mode Enc Key Rate Mask Tx Rx BVI Split-ACL Client-ACL WebAuth-ACL L2-ACL O-VLAN
RxPkts KBytes Dup Dec Mic Txc TxPkts KBytes Retry RSSI SNR Fail BAfail KeySetTs KeyClearTs1 Ts2 key
(Client) MaxPri DefUniPri DefMultPri WiredProt
IP Address Pauses Idle RateTx RateDataTx RSC SGT
MVL Req=0, In=0
Video Report: Cnt Rate Retries/Tot
8021x auth in prog 0 allowed 0
AID Hold list
radio vap id mac ssid state
Vlan BSSID Clients PSP Pri/U/M HT Flags/Encr Key0 Key1 Key2 Key3 iGTK SSIDs MFP
0n 0000 0 0 0 0 0 0 0 0 0 DIS
vap id ssid Bridging Type
Packet Tx (in radio) Metrics
Max Stuck time: Normal 0 MC 0 Off Channel 0
Stuck Cnt Normal MC Off Channel
Paks > 30 Secs 0 0 0
Paks > 20 Secs 0 0 0
Paks > 15 Secs 0
Paks > 10 Secs 0 0 0
Paks > 5 Secs 0
Paks > 1 Secs 0 0 0
Tx in radio (non zero) metrics
poison_count 0
block_free_count 0
client_null_count 0
PakTimeout:0
Protocol A2B2
Radio MAC SoC ID: 70, Rev: 4
Data Offsets: 68 76, 18 - 4, 20 - 32, 26 - 2, 42 - 1, 52 - 1, 118 - 2, 122 - 1
3F3167E4 00000005 0000006C
00000000 00040000 002B0000 00000000 FFFFFFFF
00000000 00160000 00000000 FFFFFFFF 0 0
Tx rdy 1F316B98 (1F316B98 - 1F318948) Cnt 0
1F316B98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316BD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316C18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316C58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316C98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316CD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316D18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316D58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316D98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316DD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316E18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316E58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316E98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316ED8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316F18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316F58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316F98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F316FD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317018: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317058: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317098: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3170D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317118: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317158: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317198: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3171D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317218: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317258: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317298: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3172D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317318: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317358: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317398: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3173D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317418: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317458: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317498: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3174D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317518: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317558: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317598: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3175D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317618: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317658: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317698: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3176D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317718: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317758: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317798: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3177D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317818: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317858: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317898: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3178D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317918: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317958: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317998: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3179D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317A18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317A58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317A98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317AD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317B18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317B58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317B98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317BD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317C18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317C58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317C98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317CD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317D18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317D58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317D98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317DD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317E18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317E58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317E98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317ED8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317F18: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317F58: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317F98: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F317FD8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318018: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318058: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318098: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3180D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318118: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318158: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318198: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3181D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318218: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318258: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318298: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3182D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318318: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318358: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318398: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3183D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318418: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318458: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318498: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3184D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318518: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318558: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318598: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3185D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318618: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318658: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318698: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3186D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318718: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318758: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318798: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3187D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318818: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318858: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318898: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F3188D8: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F318918: 0 0 0 0 0 0 0 0 0 0 0 0
HOST IRQ Recovered Count:0 pci_recover:0
Off Channel rdy 1F319820 (1F319820 - 1F3198C0)
1F319820: 0 0 0 0 0 0 0 0
1F3198A0: 0 0
Off Channel done 1F3198C0 (1F3198C0 - 1F319960)
1F3198C0: 0 0 0 0 0 0 0 0
1F319940: 0 0
Tx done 1F318948, current 1F318948 Cnt 0 TS 845431F1 0 0 Ptr 0 0
1F318948: 0 0 0 0 0 0 0 0
1F318968: 0 0 0 0 0 0 0 0
1F318988: 0 0 0 0 0 0 0 0
1F3189A8: 0 0 0 0 0 0 0 0
1F3189C8: 0 0 0 0 0 0 0 0
1F3189E8: 0 0 0 0 0 0 0 0
1F318A08: 0 0 0 0 0 0 0 0
1F318A28: 0 0 0 0 0 0 0 0
1F318A48: 0 0 0 0 0 0 0 0
1F318A68: 0 0 0 0 0 0 0 0
1F318A88: 0 0 0 0 0 0 0 0
1F318AA8: 0 0 0 0 0 0 0 0
1F318AC8: 0 0 0 0 0 0 0 0
1F318AE8: 0 0 0 0 0 0 0 0
1F318B08: 0 0 0 0 0 0 0 0
1F318B28: 0 0 0 0 0 0 0 0
1F318B48: 0 0 0 0 0 0 0 0
1F318B68: 0 0 0 0 0 0 0 0
1F318B88: 0 0 0 0 0 0 0 0
1F318BA8: 0 0 0 0 0 0 0 0
1F318BC8: 0 0 0 0 0 0 0 0
1F318BE8: 0 0 0 0 0 0 0 0
1F318C08: 0 0 0 0 0 0 0 0
1F318C28: 0 0 0 0 0 0 0 0
1F318C48: 0 0 0 0 0 0 0 0
1F318C68: 0 0 0 0 0 0 0 0
1F318C88: 0 0 0 0 0 0 0 0
1F318CA8: 0 0 0 0 0 0 0 0
1F318CC8: 0 0 0 0 0 0 0 0
1F318CE8: 0 0 0 0 0 0 0 0
1F318D08: 0 0 0 0 0 0 0 0
1F318D28: 0 0 0 0 0 0 0 0
1F318D48: 0 0 0 0 0 0 0 0
1F318D68: 0 0 0 0 0 0 0 0
1F318D88: 0 0 0 0 0 0 0 0
1F318DA8: 0 0 0 0 0 0 0 0
1F318DC8: 0 0 0 0 0 0 0 0
1F318DE8: 0 0 0 0 0 0 0 0
1F318E08: 0 0 0 0 0 0 0 0
1F318E28: 0 0 0 0 0 0 0 0
1F318E48: 0 0 0 0 0 0 0 0
1F318E68: 0 0 0 0 0 0 0 0
1F318E88: 0 0 0 0 0 0 0 0
1F318EA8: 0 0 0 0 0 0 0 0
1F318EC8: 0 0 0 0 0 0 0 0
1F318EE8: 0 0 0 0 0 0 0 0
1F318F08: 0 0 0 0 0 0 0 0
1F318F28: 0 0 0 0 0 0 0 0
1F318F48: 0 0 0 0 0 0 0 0
1F318F68: 0 0 0 0 0 0 0 0
1F318F88: 0 0 0 0 0 0 0 0
1F318FA8: 0 0 0 0 0 0 0 0
1F318FC8: 0 0 0 0 0 0 0 0
1F318FE8: 0 0 0 0 0 0 0 0
1F319008: 0 0 0 0 0 0 0 0
1F319028: 0 0 0 0 0 0 0 0
1F319048: 0 0 0 0 0 0 0 0
1F319068: 0 0 0 0 0 0 0 0
1F319088: 0 0 0 0 0 0 0 0
1F3190A8: 0 0 0 0 0 0 0 0
1F3190C8: 0 0 0 0 0 0 0 0
1F3190E8: 0 0 0 0 0 0 0 0
1F319108: 0 0 0 0 0 0 0 0
1F319128: 0 0 0 0 0 0 0 0
1F319148: 0 0 0 0 0 0 0 0
1F319168: 0 0 0 0 0 0 0 0
1F319188: 0 0 0 0 0 0 0 0
1F3191A8: 0 0 0 0 0 0 0 0
1F3191C8: 0 0 0 0 0 0 0 0
1F3191E8: 0 0 0 0 0 0 0 0
1F319208: 0 0 0 0 0 0 0 0
1F319228: 0 0 0 0 0 0 0 0
1F319248: 0 0 0 0 0 0 0 0
1F319268: 0 0 0 0 0 0 0 0
1F319288: 0 0 0 0 0 0 0 0
1F3192A8: 0 0 0 0 0 0 0 0
1F3192C8: 0 0 0 0 0 0 0 0
1F3192E8: 0 0 0 0 0 0 0 0
1F319308: 0 0 0 0 0 0 0 0
1F319328: 0 0 0 0 0 0 0 0
1F319348: 0 0 0 0 0 0 0 0
1F319368: 0 0 0 0 0 0 0 0
1F319388: 0 0 0 0 0 0 0 0
1F3193A8: 0 0 0 0 0 0 0 0
1F3193C8: 0 0 0 0 0 0 0 0
1F3193E8: 0 0 0 0 0 0 0 0
1F319408: 0 0 0 0 0 0 0 0
1F319428: 0 0 0 0 0 0 0 0
1F319448: 0 0 0 0 0 0 0 0
1F319468: 0 0 0 0 0 0 0 0
1F319488: 0 0 0 0 0 0 0 0
1F3194A8: 0 0 0 0 0 0 0 0
1F3194C8: 0 0 0 0 0 0 0 0
1F3194E8: 0 0 0 0 0 0 0 0
1F319508: 0 0 0 0 0 0 0 0
1F319528: 0 0 0 0 0 0 0 0
1F319548: 0 0 0 0 0 0 0 0
1F319568: 0 0 0 0 0 0 0 0
1F319588: 0 0 0 0 0 0 0 0
1F3195A8: 0 0 0 0 0 0 0 0
1F3195C8: 0 0 0 0 0 0 0 0
1F3195E8: 0 0 0 0 0 0 0 0
1F319608: 0 0 0 0 0 0 0 0
1F319628: 0 0 0 0 0 0 0 0
1F319648: 0 0 0 0 0 0 0 0
1F319668: 0 0 0 0 0 0 0 0
1F319688: 0 0 0 0 0 0 0 0
1F3196A8: 0 0 0 0 0 0 0 0
1F3196C8: 0 0 0 0 0 0 0 0
1F3196E8: 0 0 0 0 0 0 0 0
1F319708: 0 0 0 0 0 0 0 0
1F319728: 0 0 0 0 0 0 0 0
1F319748: 0 0 0 0 0 0 0 0
1F319768: 0 0 0 0 0 0 0 0
1F319788: 0 0 0 0 0 0 0 0
1F3197A8: 0 0 0 0 0 0 0 0
1F3197C8: 0 0 0 0 0 0 0 0
1F3197E8: 0 0 0 0 0 0 0 0
1F319808: 0 0 0 0 0 0
Rcv rdy 1F319960, current 1F319D5C
1F319960: 1E7209D4 1E71FF10 1E71F44C 1E71E988 1E71DEC4 1E71D400 1E71C93C 1E71BE78
1F319980: 1E71B3B4 1E71A8F0 1E719E2C 1E719368 1E7188A4 1E717DE0 1E71731C 1E716858
1F3199A0: 1E715D94 1E7152D0 1E71480C 1E713D48 1E713284 1E7127C0 1E711CFC 1E711238
1F3199C0: 1E710774 1E70FCB0 1E70F1EC 1E70E728 1E70DC64 1E70D1A0 1E70C6DC 1E70BC18
1F3199E0: 1E70B154 1E70A690 1E709BCC 1E709108 1E708644 1E707B80 1E7070BC 1E7065F8
1F319A00: 1E705B34 1E705070 1E7045AC 1E703AE8 1E703024 1E702560 1E701A9C 1E700FD8
1F319A20: 1E700514 1E6FFA50 1E6FEF8C 1E6FE4C8 1E6FDA04 1E6FCF40 1E6FC47C 1E6FB9B8
1F319A40: 1E6FAEF4 1E6FA430 1E6F996C 1E6F8EA8 1E6F83E4 1E6F7920 1E6F6E5C 1E6F6398
1F319A60: 1E6F58D4 1E6F4E10 1E6F434C 1E6F3888 1E6F2DC4 1E6F2300 1E6F183C 1E6F0D78
1F319A80: 1E6F02B4 1E6EF7F0 1E6EED2C 1E6EE268 1E6ED7A4 1E6ECCE0 1E6EC21C 1E6EB758
1F319AA0: 1E6EAC94 1E6EA1D0 1E6E970C 1E6E8C48 1E6E8184 1E6E76C0 1E6E6BFC 1E6E6138
1F319AC0: 1E6E5674 1E6E4BB0 1E6E40EC 1E6E3628 1E6E2B64 1E6E20A0 1E6E15DC 1E6E0B18
1F319AE0: 1E6E0054 1E6DF590 1E6DEACC 1E6DE008 1E6DD544 1E6DCA80 1E6DBFBC 1E6DB4F8
1F319B00: 1E6DAA34 1E6D9F70 1E6D94AC 1E6D89E8 1E6D7F24 1E6D7460 1E6D699C 1E6D5ED8
1F319B20: 1E6D5414 1E6D4950 1E6D3E8C 1E6D33C8 1E6D2904 1E6D1E40 1E6D137C 1E6D08B8
1F319B40: 1E6CFDF4 1E6CF330 1E6CE86C 1E6CDDA8 1E6CD2E4 1E6CC820 1E6CBD5C 1E6CB298
1F319B60: 1E6CA7D4 1E6C9D10 1E6C924C 1E6C8788 1E6C7CC4 1E6C7200 1E6C673C 1E6C5C78
1F319B80: 1E6C51B4 1E6C46F0 1E6C3C2C 1E6C3168 1E6C26A4 1E6C1BE0 1E6C111C 1E6C0658
1F319BA0: 1E6BFB94 1E6BF0D0 1E6BE60C 1E6BDB48 1E6BD084 1E6BC5C0 1E6BBAFC 1E6BB038
1F319BC0: 1E6BA574 1E6B9AB0 1E6B8FEC 1E6B8528 1E6B7A64 1E6B6FA0 1E6B64DC 1E6B5A18
1F319BE0: 1E6B4F54 1E6B4490 1E6B39CC 1E6B2F08 1E6B2444 1E6B1980 1E6B0EBC 1E6B03F8
1F319C00: 1E6AF934 1E6AEE70 1E6AE3AC 1E6AD8E8 1E6ACE24 1E6AC360 1E6AB89C 1E6AADD8
1F319C20: 1E6AA314 1E6A9850 1E6A8D8C 1E6A82C8 1E6A7804 1E6A6D40 1E6A627C 1E6A57B8
1F319C40: 1E6A4CF4 1E6A4230 1E6A376C 1E6A2CA8 1E6A21E4 1E6A1720 1E6A0C5C 1E6A0198
1F319C60: 1E69F6D4 1E69EC10 1E69E14C 1E69D688 1E69CBC4 1E69C100 1E69B63C 1E69AB78
1F319C80: 1E69A0B4 1E6995F0 1E698B2C 1E698068 1E6975A4 1E696AE0 1E69601C 1E695558
1F319CA0: 1E694A94 1E693FD0 1E69350C 1E692A48 1E691F84 1E6914C0 1E6909FC 1E68FF38
1F319CC0: 1E68F474 1E68E9B0 1E68DEEC 1E68D428 1E68C964 1E68BEA0 1E68B3DC 1E68A918
1F319CE0: 1E689E54 1E689390 1E6888CC 1E687E08 1E687344 1E686880 1E685DBC 1E6852F8
1F319D00: 1E684834 1E683D70 1E6832AC 1E6827E8 1E681D24 1E681260 1E68079C 1E67FCD8
1F319D20: 1E67F214 1E67E750 1E67DC8C 1E67D1C8 1E67C704 1E67BC40 1E67B17C 1E67A6B8
1F319D40: 1E679BF4 1E679130 1E67866C 1E677BA8 1E6770E4 1E676620 1E675B5C 0
Rcv done 1F319D60, current 1F319D60
1F319D60: 0 0 0 0 0 0 0 0
1F319D80: 0 0 0 0 0 0 0 0
1F319DA0: 0 0 0 0 0 0 0 0
1F319DC0: 0 0 0 0 0 0 0 0
1F319DE0: 0 0 0 0 0 0 0 0
1F319E00: 0 0 0 0 0 0 0 0
1F319E20: 0 0 0 0 0 0 0 0
1F319E40: 0 0 0 0 0 0 0 0
1F319E60: 0 0 0 0 0 0 0 0
1F319E80: 0 0 0 0 0 0 0 0
1F319EA0: 0 0 0 0 0 0 0 0
1F319EC0: 0 0 0 0 0 0 0 0
1F319EE0: 0 0 0 0 0 0 0 0
1F319F00: 0 0 0 0 0 0 0 0
1F319F20: 0 0 0 0 0 0 0 0
1F319F40: 0 0 0 0 0 0 0 0
1F319F60: 0 0 0 0 0 0 0 0
1F319F80: 0 0 0 0 0 0 0 0
1F319FA0: 0 0 0 0 0 0 0 0
1F319FC0: 0 0 0 0 0 0 0 0
1F319FE0: 0 0 0 0 0 0 0 0
1F31A000: 0 0 0 0 0 0 0 0
1F31A020: 0 0 0 0 0 0 0 0
1F31A040: 0 0 0 0 0 0 0 0
1F31A060: 0 0 0 0 0 0 0 0
1F31A080: 0 0 0 0 0 0 0 0
1F31A0A0: 0 0 0 0 0 0 0 0
1F31A0C0: 0 0 0 0 0 0 0 0
1F31A0E0: 0 0 0 0 0 0 0 0
1F31A100: 0 0 0 0 0 0 0 0
1F31A120: 0 0 0 0 0 0 0 0
1F31A140: 0 0 0 0 0 0 0 0
Off Channel scheduler statistics: (mSec)
Priority avg_wait_time avg_serve_time timeout_count flush_count request_count
0 0 0 0 0 0
1 0 0 0 0 0
2 0 0 0 0 0
3 0 0 0 0 0
4 0 0 0 0 0
off chan inprog = 0
offchannel flush inprog:No
offchannel queue flush = 0
Last 4 Radio Req stats
ReqId RdyTs DoneTs
0 0 0
0 0 0
0 0 0
0 0 0
Current Ts:845A3AFF
KeyPlumbCnt:0
TXSM Jammer information:
State: 0
Flags: 00000000
Beacons seen: 0
Time since: 0
Jammer Radio resets: 0
TXSM Beacon information:
Monitoring State: 0
Flags: 80000202
Beacons seen: 0
Time since: 2220
Max Time w/o beacons: 0
Beacon stopped count: 0
Counts > 120 0
Counts > 90 0
Counts > 60 0
Counts > 30 0
Counts > 15 0
Counts > 10 0
Counts > 5 0
TXSM Current Beacon Outage:
Beacon Monitor Flags OP Mode Flags Reason
0x80000202 0x00000000 Capwap down, No serving channel,
TXSM Beacon Outage Stats:
Outage(Seconds) Beacon Monitor Flags OP Mode Flags Reason
> 120
> 90
> 60
> 30
> 15
> 10
> 5
Last Cmd Received Time:84542315
Last stats update: 2220
Current Time:2220 845B3C27
Last Tx Ev:00000000
Last Off chnl Ev:00000000
Last Off chnl intr ret:00000000
Radio PCI resets:0
RX Ring Errors - Pak:0 Order:0 Max:0
Radio commands - total:9762 delayed:0 elapsed:0 timeouts:0 time high 00000000 low 00000000 usecs 00000000
Log buf magic 0(FA1A1AFA) 1(00000000) Active(0) 1F31A5B8 Last(1) 1F31AAAC
Before H2a TS:845422AF
Last cmd host 17 fw 17 HTS 845422B0 FWWD 824723E2 PP 0 MAGIC FA1A1AFA
FW Stats Pak 0 Mac S/D 0/0
EU Submit/Done Stats
Q0 0/0
Q1 0/0
Q2 0/0
Q3 0/0
Q4 0/0
Q5 0/0
Q6 0/0
Q7 0/0
CMD(06) - TS HOST 00000000 FW 00045A07 seq 6
CMD(12) - TS HOST 00000000 FW 5920F620 seq 6
CMD(14) - TS HOST 00000000 FW 00045ECC seq 6
CMD(16) - TS HOST 84542272 FW 8240EB5E seq 6
CMD(17) - TS HOST 00000000 FW 8240EBA8 seq 6
CMD(1E) - TS HOST 00000000 FW 000460D9 seq 6
CMD(22) - TS HOST 00000000 FW 0005A231 seq 6
CMD(39) - TS HOST 00000000 FW 00045E30 seq 6
Well aligned packets transmitted: 0
Misaligned packet transmitted: 0
### Tx Power: Dot11 Config
Serving Channel 0 (Type 0)
Active Level Index 1 (Unitless)
Active Level 17 dBm (OFDM 17 dBm)
IEEE MIB format TRUE
Metric unit dBm
HD Active 127
Low Power Mode Set High (Active: Set High)
Cookie max 17
Client Power Max 32767, Active Max 0 (Asymmetric)
Regulatory Limit 30
Modulation Index 4
Antenna Selection External, Rx: 0 active in [ ] Tx: 4 active in [ABCD]
Antenna Gain Reported:Configured:InUse = [8:0:12] (2 x dBi)
Allowed Power Levels Total 6 levels in TPO [17/14/11/8/5/2] Per-ant [11/8/5/2/-1/-4]
HAL Per antenna Tx Power (in dBm)
CCK :
OFDM : LBF : HT20-7 : HT20-15 : HT20-23 : HT40-7 :
HT40-15 : HT40-23 : N-HT40 Dup : HT20 BF-7 : HT20 BF-15 : HT20 BF-23 :
HT40 BF-7 : HT40 BF-15 : HT40 BF-23 : HT20 STBC-7 : HT40 STBC-7 :
VHT20-1s : VHT20-2s : VHT20-3s :
VHT40-1s : VHT40-2s : VHT40-3s :
VHT80-1s : VHT80-2s : VHT80-3s :
N-HT80DUP :
VHT20BF-1s : VHT20BF-2s : VHT20BF-3s :
VHT40BF-1s : VHT40BF-2s : VHT40BF-3s :
VHT80BF-1s : VHT80BF-2s : VHT80BF-3s :
VHT20ST : VHT40ST : VHT80ST :
0 0 0 0 :
0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 :
0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 0 0 : 0 0 0 0 0 0 0 0 0 0 :
0 0 0 0 0 0 0 0 :
Dynamic Antenna Activation: Number of active antennas
0 0 0 0 :
0 0 0 0 0 0 0 0 :
Max per-path TxPower at modulation (at operation condition)
6.0 to a9.1t8, 0 dBm
DOT11 Statistics (Cumulative Total/Last 5 Seconds):
RECEIVER TRANSMITTER
Host Rx K Bytes: 0 / 0 Host Tx K Bytes: 0 / 0
Unicasts Rx: 0 / 0 Unicasts Tx: 0 / 0
Unicasts to host: 0 / 0 Unicasts by host: 0 / 0
Broadcasts Rx: 0 / 0 Broadcasts Tx: 0 / 0
Beacons Rx: 0 / 0 Beacons Tx: 0 / 0
Broadcasts to host: 0 / 0 Broadcasts by host: 0 / 0
Multicasts Rx: 0 / 0 Multicasts Tx: 0 / 0
Multicasts to host: 0 / 0 Multicasts by host: 0 / 0
Mgmt Packets Rx: 0 / 0 Mgmt Packets Tx: 0 / 0
RTS received: 0 / 0 RTS transmitted: 0 / 0
Duplicate frames: 0 / 0 CTS not received: 0 / 0
CRC errors: 0 / 0 Unicast Fragments Tx: 0 / 0
WEP errors: 0 / 0 Retries: 0 / 0
Buffer full: 0 / 0 Packets one retry: 0 / 0
Host buffer full: 0 / 0 Packets > 1 retry: 0 / 0
Header CRC errors: 0 / 0 Protocol defers: 0 / 0
Invalid header: 0 / 0 Energy detect defers: 0 / 0
Length invalid: 0 / 0 Jammer detected: 0 / 0
Incomplete fragments: 0 / 0 Packets aged: 0 / 0
Rx Concats: 0 / 0 Tx Concats: 0 / 0
R2H Buffer full: 0 / 0
Rx err len pkt: 0 / 0
Tx Watchdog stats:
Tx SW Watchdog 0 / 0
Tx HW Watchdog 0 / 0
ATF Radio Configuration:
Mode : Disabled
Multicast throttle drops: 0
Client TX pause count: 0
Bad receive packet count: 0
Media Direct Band Configuration
Unicast Video Redirect = 0
Client Min Phy Rate = 0
Max Retry Percentage = 0
Dot11 Current Video Transmission Metrics:
Arrivals:0 Q-Drops:0 Tries:0 Agg:0 Success:0 Fail:0
Dot11 5-second Video Transmission Metrics:
Arrivals:0 Tries:0 Agg:0 Success:0 Fail:0
Radio-Q-Peak:0 Video-Q-Peak:0 Video-Q-Drops:0
Delay - Tot Msec:0 10/20/40/40+ Msec:0/0/0/0
Dot11 1-second Video Transmission Metrics:
Q-util:0 max-tx-time:0 p-chan:0 p-video:0 L/r:0
Extended Radio Parameters:
Beacon period (not supported), range (not supported)
Ext Conf flags: 0
Mcast rate 0 Mbps (Disabled)
RX sensitivity -0 dB (Disabled)
CCA threshold -0 dB (Disabled)
Coverage Report Interval - 90
802.11 forwarding statistics:
IDB fastsend:0 frame_tx:0 frame_rx:0 vidb_tx:0
Global mcast TX - total:0 mc2uc:0 drops:0 bad pri:0
IDB mcast TX - filter:0,0,0 igmp_filter:0 from_self:0
MGMT Action - GAS Req Rcvd:0 GAS Req Rx Drop:0
Global DMS - requests:0 uc:0 drop:0
DMS enabled on WLAN(s):
DMS database:
Log Buffer:
Last radio RC(40)
Radio resets - total:15 retries:0 failed:0
Reset Stats: Start Cnt: 4, Recovery: Cnt 0, Last Ret: 1000, Fails: 0, Recvry Status: Stalled NO, In Prog NO
Normal:
Code Count State When
10 9 STOP 15:56:55.642 GMT Wed Feb 3 2021
39 1 START 00:00:37.683 GMT Mon Mar 1 1993
40 5 STOP 16:17:53.611 GMT Wed Feb 3 2021
Prefetch: Trigger Active: 0 Recovery Disabled?: 0
Prefetch: Stats updated every 10 seconds. Time since trigger:0
Prefetch: Trigger cnt: 0
Prefetch Limits: Legacy - 500 11ac - 10000 300000
bifrost-cisco3702e-REAR#show int dot11 1
Dot11Radio1 is reset, line protocol is down
Hardware is 802.11AC 5GHz Radio, address is b026.80a1.16b0 (bia b026.80a1.16b0)
Description: 802.11 5GHz a n
MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
Keepalive set (10 sec)
Last input never, output never, output hang never
Input queue: 0/42878/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/30 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
bifrost-cisco3702e-REAR>
bifrost-cisco3702e-REAR>reload
Translating "reload"...domain server (8.8.8.8)
% Bad IP address or host name
% Unknown command or computer name, or unable to find computer address
bifrost-cisco3702e-REAR>enable
Password:
bifrost-cisco3702e-REAR#reload
Proceed with reload? [confirm]
Writing out the event log to flash:/event.log ...
Write of event.log done
Feb 3 16:35:18.076: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 11
Feb 3 16:35:18.084: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 303 files, 14 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 28749312
flashfs[0]: Bytes available: 12409344
flashfs[0]: flashfs fsck took 24 seconds.
Base Ethernet MAC address: b0:26:80:9d:bd:18
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-mx.153-3.JPK"...#########################
File "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-mx.153-3.JPK" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Montserrat Board
40MB format
flashfs[0]: flashfs fsck took 26 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Boot CMD: 'boot flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK;flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK'
Loading "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK"...###########################################
File "flash:/ap3g2-k9w7-mx.153-3.JPK/ap3g2-k9w7-xx.153-3.JPK" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-K9W7-M), Version 15.3(3)JPK, RELEASE SOFTWARE (fc1)
Compiled Tue 24-Nov-20 03:58 by prod_rel_team
Montserrat Board
40MB format
Initializing flashfs...
flashfs[2]: 303 files, 14 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 28749312
flashfs[2]: Bytes available: 12151296
flashfs[2]: flashfs fsck took 18 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/R2.bin
Radio1 present 8864 8000 0 80000000 80100000 4
POWER TABLE FILENAME = ram:/R5.bin
Radio2 not present 0 0 0 0 0 8
export@cisco.com.
2 802.11 Radios
Translating "uk.pool.ntp.org"...domain server (8.8.8.8) (8.8.4.4) (192.168.0.42)
Press RETURN to get started!
*Mar 1 00:00:23.467: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:29.615: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar 1 00:00:29.727: loading Power Tables from ram:/R2.bin. Class = A
*Mar 1 00:00:29.731: record size of 3ss: 1168 read_ptr: 43DBCE6
*Mar 1 00:00:34.927: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot1CCCCCCCC
* You are connected to CISCO 3702e Access Point at ip 192.168.0.105
bifrost-cisco3702e-REAR>1Radio 1 (4)
*Mar 1 00:00:34.971: loading Power Tables from ram:/R5.bin. Class = B
*Mar 1 00:00:35.007: record size of vht: 2904 read_ptr: 43DBCE6
*Mar 1 00:00:35.143: SCHED: Ethernet Bridge Process: install watched boolean System Initialized(43C3F2C), os:1 ah:0
*Mar 1 00:00:37.235: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:37.631: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 39
Translating "uk.pool.ntp.org"...domain server (8.8.8.8)XPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 39
*Mar 1 00:00:37.635: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:37 UTC Mon Mar 1 1993 to 00:00:37 GMT Mon Mar 1 1993, configured from console by console.
*Mar 1 00:00:37.647: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:00:37.647: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Mar 1 00:00:38.227: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 40
*Mar 1 00:00:38.235: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:00:38.235: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 40
*Mar 1 00:00:38.239: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Mar 1 00:00:38.251: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 40
*Mar 1 00:00:38.271: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Mar 1 00:00:38.287: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar 1 00:00:39.283: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:01:32.395: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:01:32.511: Starting Etherne [OK]
t promiscuous mode
*Mar 1 00:01:32.511: %SYS-5-RESTART: System restarted --
*Mar 1 00:01:32.511: %SNMP-5-COLDSTART: SNMP agent on host bifrost-cisco3702e-REAR is undergoing a cold start
*Feb 3 16:35:17.027: SCHED: Ethernet Bridge Process: remove watched boolean System Initialized(43C3F2C)
*Feb 3 16:35:17.027: SCHED: Ethernet Bridge Process: install watched queue Soap BVI input queue(43B65BC), os:0 ah:0
*Feb 3 16:35:17.027: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Feb 3 16:35:17.031: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 3 16:35:17.031: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Feb 3 16:35:17.031: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Feb 3 16:35:17.031: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
*Feb 3 16:35:17.031: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power source
*Feb 3 16:35:18.035: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Feb 3 16:35:18.035: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Feb 3 16:35:18.147: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 3 16:35:19.027: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Feb 3 16:35:19.147: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Feb 3 16:35:19.151: %DOT11-4-NO_SSID_VLAN: No SSID with VLAN configured. Dot11Radio1 not started.
*Feb 3 16:35:19.155: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Feb 3 16:35:19.163: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 3 16:35:20.027: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Feb 3 16:35:20.155: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Feb 3 16:35:20.191: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 3 16:35:21.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Feb 3 16:35:21.687: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (0-0)
*Feb 3 16:35:21.687: DPAA Initialization Complete
*Feb 3 16:35:21.687: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Feb 3 16:35:22.687: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Feb 3 16:35:24.687: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Feb 3 16:35:25.687: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
Your logs clearly show the problem
Refer https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-appC-errormsg.html
Discussed on https://community.cisco.com/t5/wireless/dot11-4-no-ssid-vlan-but-i-put-my-ssid-s-in-a-vlan-didn-t-i/m-p/1032111
struggling to understand this
i can see %DOT11-4-NO_SSID_VLAN: on the console,
but i was sure i had to config i need. why it would say this is beyond me.
dave
the issue was staring me in the face all this time lol
encapsulation dot1Q 2 native
no ip route-cache
no cdp enable
bridge-group 1
the encapsulation dot1Q was on vlan 1
im all good now haha, amazing
dave
thanks for all your help, whoever you were, really appreciate it,
i can now put my mind to rest for this particular issue,
thanks again
dave
