Issues on posture enabled SSID
hdshamal26
Frequent Visitor
Frequent Visitor
We have one posture enabled SSID in our wireless network. It is not seamlessly work compared to other SSIDs. The main difference is posture feature has enabled on it. Below are the list of issues. Please share your experiences to overcome from these issues.
1. Globe icon is not changed to the WIFI icon soon after user connected to the SSID. It will take time to change the icon after the posture process completed. Though the icon doesn't change user has access to the network (Both intranet & internet via proxy)
2. Connected to the SSID. But "No internet" massage appeared. At this time no internet access even after ore than 5 minutes.
3. "Action Needed" when user connected to the SSID it prompt "Action Needed for <SSID name>". Though this is appeared some times user have access to the network. Some times not.
4. Users are experiencing sudden disconnection from the SSID.
Mark Elsen
 - You can for instance  , check the ISE live logs when a client connects and then verify if according to posture sequence executed , that access is granted or rejected,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
srimal99
Level 5
Level 5
You can check the radius  live logs, and check against the authorization rule are matching accordingly.I have had similar issue anyconnect not joined but ise logs shows client connected.
There are some cisco ISE videos below for your reference;
https://www.youtube.com/watch?v=AxgtXynug_E
https://www.youtube.com/watch?v=14ozZzOE_zM
Rich R
Not enough detail provided to say for certain but I'd guess this is related to radius CoA not reaching the WLC or not being allowed.
Have you enabled CoA and allowed it through ACLs and Firewalls?
In wireless profile policy "aaa-override"
"aaa server radius dynamic-author" must include all your radius server(s)
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113344-cuwn-ppm.html#toc-hId--1639616132
Source Device
Destination Device
Protocol
Destination Port
Source Port
Description
RADIUS server
WLC
UDP
1700
0::65535
CoA radius packets
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
