Issues with Aironet 1142 and iPhone/iPad Connectivity
nautica4132
I setup the Aironet with local Radius authentication WPA2.  I am able to connect with both PC's and Mac desktops and Laptops, however both iPhone and iPads I have tried to connect it attempts, then after 45 seconds they display "Cannon Connect".  I have searched forums and Google for an answer and have found none.  Please help.
Sam
Pulkit Nagpal
Moving to Wiresless communitu for better support.
Pulkit Nagpal
Community Manager- R&S
Surendra BG
Post ur Config which is present on the AP. "show run" from the AP..
Surendra
Surendra BG
my iphone or ipad can connect to ap1142 nicely.
however, there are another vendor devices, very special is electronic component which can support wifi.
after the device connected for few seconds, or even few minutes, suddenly it get 192.168.1.1 IP address, i believe this IP is default or what?
why it getting this IP, then sometimes after certain while, it can get back the original IP, which our range is 10.x.x.x
and i refer to the log, it said this devices keep authentication fail or client had reached max retries
i had put the command which packet retry 128 drop, or similar, but not help.
