IW6300H Mesh AP not joined the Controller through Root AP after reboot
wahyudi
Hi all,
My setup:
WLC: Cisco Catalyst 9800 Series (RMI-RP HA Mode)
Firmware Version: 17.04.01 (Bengaluru)
RAP: Cisco IW-6300H - using static IP, PoE Switch power input
MAP: Cisco IW-6300H - using static IP, AC power input
Situation 1: MAP connected direct to network switch using network cable -> MAP join to WLC thru ethernet backhaul
Situation 2: disconnect network cable -> MAP join to WLC thru RAP backhaul
Situation 3: MAP reboot -> MAP cannot join WLC & searching for radio channel
Please advise
wahyudi
It seems there is a bug in the firmware, so I downgrade to firmware version 17.3.2a and the MAP now can join WLC thru RAP
Here is the link from the bug search tool -> https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv68294
joyaljp
Did you add the MAC of the MAP to the WLC? You need this for Mesh to work when you are connecting through RAP.
I add the MAC of all AP in Device Authentication
-> Configuration>Security>AAA>AAA Advanced>Device Authentication
wahyudi
