07-23-2024 12:29 PM
Hi team
I have some IW3702 with 4 antennas AIR-ANT2547V-N and working fine and the installation it's very simple use port 1,2,3 and 4. Now I need upgrade this access point for IW9167EH and I have quetions about the intefaces radios and antenna instaltion, I want use the same 4 antenas AIR-ANT2547V-N for radios 2.4Ghz and 5Ghz.
My first thought is use the port 1,2,3,4 but in the instalation guide we have this note
So I don't know which port to use for use the same antenas whitout a adicional cable o mount for the antennas
Regards.
07-25-2024 09:57 AM
Any idea? I don't know if in the notes is port 1 - 4 and 5 - 8 it's a range or it's only this port.
Regards.
10-03-2024 02:54 AM
if you use antenna ports 1,2,3,4 for 5GHz, you cannot use ports 5,6,7,8 for 5GHz also. It will create RF interference being that close on independent radio chips.
07-28-2024 04:26 AM
Ports 1 - 4 (meaning ports 1, 2, 3 & 4) are for dual band (2.4 and 5 GHz) antennas
Ports 5 - 8 (meaning ports 5, 6, 7 & 😎 are for 5 GHz antennas only
So you can use AIR-ANT2547V-N on ports 1-4.
