l need help cisco
lisavbedt
Level 3
Level 3
l have ordered 25 cisco used but l cant configure l put en then conf t it says input marker
l have smc switch how configure cisco is so hard someone help with cisco
wlc could not discover  dhcp ip
23 Replies 23
can you explain more detail about wlc could not discover dhcp ip
you mean management ip ? what is the wlc model? and how do you config it ?
*Mar 1 00:17:18.013: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP
it says it l dont how confgure it someone can help would be useful
model air-LAP1142N-E-K9
l dont have cisco controller switch l have only router ip 192.168.178.1 how configure l dont know it l watched video how to confiure didn help not so useful
connect console cable to ap
"ap>enable
ap#conf t
ap(config)#int bv1
ap(config-if)#ip add x.x.x.x x.x.x.x
ap(config-if)#end
lisavbedt
Level 3
Level 3
l typed i didn work it says invaild input marker
l cant configure
You need to have a console cable and then console into the ap.  Search for FTDI USB to RJ45
https://www.amazon.com/OIKWAN-Compatible-Opengear-Aruba%EF%BC%8CJuniper-Switches/dp/B075V1RGQK/ref=sxin_16_pa_sp_search_thematic_sspa?content-id=amzn1.sym.824ce8c0-071d-4ae0-a0bd-93ac8c4d5e37%3Aamzn1.sym.824ce8c0-071d-4ae0-a0bd-93ac8c4d5e37&cv_ct_cx=...
If the ap's are leap like the model you posted "LAP" then you need a controller.
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/70278-lap-faq.html
Also the "E" on the model you have means, requires an external antenna.  So you need to make sure you have the proper antenna for your environment.
-Scott
no l have one famale cable to rj45 why do need another one? ask qustion
You don't.... the point was if you didn't have one and wanted to get one.  As long as it works and you can get output from the console you are fine.
-Scott
lisavbedt
Level 3
Level 3
ask qustion l dont how configure it model is air-LAP1142N-E-K9  input marker l need confiugre it but l dont know how
open console enable ok when l put typed conf t it says input marker
air-LAP1142N-E-K9 model you see lap sign l dont have cisco wireless controller how the hell do configure that cisco airnet
someone can help us with idea
You need a wireless lan controller with the model of ap you have.  IF you wanted to not use a wireless lan controller, you should have purchased air-ap11142n-e-k9.  You can try to convert it, but you will need to search the internet for the image.
https://community.cisco.com/t5/wireless/how-to-convert-a-cisco-ap-from-lightweight-to-autonomous-cap-to/td-p/3067866
-Scott
air-LAP1142N-E-K9  - what are you trying to configured, if the AP is configured already you need to reset to factory ?
here is the configuration guide :
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap4-first.html
Note as suggested above, you need to connect the console and post the complete output here (in TEXT File) so we understand what is wrong with the AP, why you are not able to configure so on.
l don't have a cisco wireless controller how the hell do configure that cisco AP  <--- what is your goal of buying used AP  here ?
BB
l reset it but it still saying dhcp and wlc error
l ordered cisco by marktplace used
You ordered the wrong model.
-Scott
l cant reteurn and l kind wireless controller do l needed ? do ever controller to this ap?
you should look for a WLC 2504 and make sure it has this code version 8.3.150.0. Here is a matrix of the supported code for the 1140.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Also take a look at the section where they show AireOS controllers and the supported code versions:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#ctrl-sw_rls
-Scott
