L3 switch having ethernet module?
spitz1995
Community Member
Hello.
I'm looking for L3 switch which has a place to insert ethernet interface module into it.
Are there such products?
I've thought that all L3 switches don't have such a place (although they have a place to insert SFP module).
And, I'm happy if the product you introduce to me can create 4094 or more VLANs .
Please answer.
 48 or more ports
12 or more interfaces
The cheapest is the 3850 family of switches.  There are switch models with 48 port ethernet ports (non-PoE, PoE/PoE+, uPoE, mGIG).
Again, 3850 has several SFP+ models, 12-, 24- and 48 ports.
5 Replies 5
Leo Laohoo
What are you trying to achieve and what's your budget?
There are a lot of Cisco switches that are modular.  How many Ethernet ports and how many SFP ports are you looking for?
Thanks,Leo Laohoo.
①Ethernet ports(10/100/1000BASE-Tmodule)
 48 or more ports
②SFP ports(1000BASE-Xmodule or 10GBASE-Rmodule)
 We'd like  Catalyst 3XXX to serve as distribution or access switch
(Sorry,we just look for the switch because our boss want .We don't know his object ).
 We don't care how much the switch is.
 48 or more ports
Thanks for your answer.
I've solved the problem.
Someday I'd like your advice if I have another question.
Thanks for taking the time to rate our posts.  🙂
