layer 3 network separate between controller LAP
please find the attachment . AS i configured on the file   ,  LAP1 register successfully on the controller then i configured two SSID with different subnet . the problem user who try to access the LAP can't gets IP also controller can't ping the gateway of the two WLAN .
5 Replies 5
Your quesion is better suited in English CSC Wireless, https://supportforums.cisco.com/community/netpro/wireless-mobility. You can move this thread from 'Move Discussion' under Actions. Can you please try it?
Cisco Support Community Japan
Rasika Nayanajith
As per your attachment WLC is having trunk link to Core Switch.  You have defined SVI interfaces on Distribution switch. There is  no layer 2 connection between your Core switch & Distutribution switch. Therefore you cannot establish communication between WLC & SVI (as they are not in same layer 2 network). You can do one of this to fix it
1. Move WLC into Distribution switch.
OR
2. Define vlan530,630 (user vlan) on Core switch instead of distribution (including DHCP pools)
Rasika
Dear Rasika ,
if i creat Vlan 730 , 630 and DHCP pool on  core switch , you also want to me to creat
Interface Vlan 630                                                               Interface Vlan 730
Ip address 172.16.40.1                                                     ip address 172.50.18.1
on core switch .
how user can reach to thier gateway on core switch although the first step for user on distributed ????
DO u think i need to make AP mode to REAP ?
Yes, Othewise you need to use "ip helper address" command to pointing to Distribution switch as DHCP server.
AP will establish a CAPWAP tunnel between AP & WLC, therefore users won't required to be on a vlan available in distribution switch.
You do not want to convert AP in to H-REAP mode to get this working.
