05-09-2011 02:33 PM - edited 07-03-2021 08:10 PM
Is LDAP web authentication supported on the AIR-WLC2006-K9? There is a place to add LDAP servers in there but I can't seem to get the web authentication piece of it to work. I saw some idications on forum posts online that made me think that it wasn't supported but I never found a definitive cisco answer. I have it set up and working great on a 5508 wireless controller.
Tate
Solved! Go to Solution.
05-09-2011 11:16 PM
LDAP with web authentication only shows up in 5.0 config guides and later.
The 2006 only supports up to 4.2 software. I think this should answer your question :-) It's a no
05-09-2011 11:16 PM
