11-23-2003 07:54 AM - edited 07-04-2021 09:10 AM
I am trying to implement WPA and LEAP on small home network. I use a Windows XP Pro laptop with PCM352 client and an Aironet 350 Access Point.
I've upgraded the 350 to IOS and also did the PCM352 card software upgrade to the latest 1.2 version.
Since I don't have a RADIUS server, I want to use the AP as local authenticator.
I added the following to the AP:
aaa new-model
aaa authentication login default local
radius-server local
nas 192.168.1.20 key xxxxxxxxxxxxxxx
user yyyyyyy password zzzzzzzzzzzz
interface Dot11Radio0
encryption mode ciphers tkip wep128
ssid xxxxxxx
authentication network-eap default
authentication key-management wpa
However, LEAP authentication times out. I think I configured it correctly in ACU 6.2 so it has to be something I did wrong on the AP.
Can anyone point me in the right direction to what I am missing? I read the Software Configuration guide several times and I am unable to put all pieces together. Any sample configs for what I want to do? Thank you very much in advance.
11-24-2003 04:53 PM
You're missing a couple things...
Even tho your AP is configured as a local authenticator, you still need to define what server-group to use for what:
aaa group server radius rad_eap
server x.x.x.x auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
Even tho your AP is configured as a local authenticator, you still need to tell him who his RADIUS server is:
radius-server host x.x.x.x auth-port 1812 acct-port 1813 key whatever
radius-server attribute 32 include-in-access-req format %h
radius-server authorization permit missing Service-Type
radius-server vsa send accounting
Also, I don't think you set up the authentication correctly under the ssid. Mine looks like this:
ssid xxxxx
# allow static WEP clients
authentication open
# allow LEAP clients
authentication network-eap eap_methods
The first couple times, you should probably use the web gui to set this up; the IOS config is arcane unless your strong with it. Also, you might want to back off the tkip and wpa until you get LEAP authentication working correctly, then add those in after.
It helps greatly if you have a wired pc that you can telnet into the AP with then:
terminal monitor
debug aaa authentication
You'll see what's bombing this way....
Good Luck!
11-26-2003 08:04 PM
Thank you so much for your reply! I have worked on this some more but still can't get it to work. The LEAP Authentication always times out. I reset the AP to factory defaults several times trying different things. Here is my latest config. This is the way I think it "should" be but I am obviously wrong! I've used the GUI to do this...
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname ap
username uuuuuuuu privilege 15 password 7 00000000000
clock timezone R -5
clock summer-time R recurring
ip subnet-zero
ip domain name ddddddddddddd.com
ip name-server 192.168.1.40
aaa new-model
server 192.168.1.20 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
bridge irb
no ip address
no ip route-cache
ssid ssssssssss
authentication open eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
power local 50
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.20 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
/ivory/1100
ip http authentication aaa
ip radius source-interface BVI1
no logging trap
radius-server local
nas 192.168.1.20 key 7 000000000000
user uuuuuuuuu nthash 7 0000000000000000000000000000000000000
radius-server host 192.168.1.20 auth-port 1645 acct-port 1646 key 7 000000000000
bridge 1 route ip
line con 0
stopbits 1
line vty 5 15
end
11-26-2003 08:24 PM
I forgot to mention that I used debug aaa authentication:
Nov 26 23:04:53.288 R: %DOT11-7-AUTH_FAILED: Station 000a.f44a.4dac Authenticati
on failed
Nov 27 04:04:53.405: AAA/AUTHEN/PPP (00000039): Pick method list 'eap_methods'
...and also debug radius which shows no server found???
Nov 27 04:08:20.296: RADIUS(00000046): Retransmit id 21645/68
Nov 27 04:08:25.304: RADIUS: Tried all servers.
Nov 27 04:08:25.304: RADIUS: No valid server found. Trying any viable server
Nov 27 04:08:25.304: RADIUS: No response from (192.168.1.20:1645,1646) for id 21
645/68
Nov 27 04:08:25.304: RADIUS/DECODE: parse response no app start; FAIL
Nov 27 04:08:25.304: RADIUS/DECODE: parse response; FAIL
Nov 26 23:08:25.308 R: %DOT11-7-AUTH_FAILED: Station 000a.f44a.4dac Authenticati
on failed
Nov 27 04:08:25.513: RADIUS: AAA Unsupported [143] 3
Nov 27 04:08:25.513: RADIUS: 33
[3]
Nov 27 04:08:25.513: RADIUS(00000047): Storing nasport 326 in rad_db
Nov 27 04:08:25.513: RADIUS: Pick NAS IP for uid=71 tableid=0 cfg_addr=192.168.1
.20 best_addr=0.0.0.0
Nov 27 04:08:25.517: RADIUS/ENCODE(00000047): acct_session_id: 71
Nov 27 04:08:25.517: RADIUS: Pick NAS IP for uid=71 tableid=0 cfg_addr=192.168.1
Nov 27 04:08:25.517: RADIUS(00000047): sending
Nov 27 04:08:25.517: RADIUS(00000047): Send Access-Request to 192.168.1.20:1645
id 21645/69, len 127
Nov 27 04:08:25.521: RADIUS: authenticator E5 B6 54 2F F8 9E F6 50 - AB 52 AF B
A 7C 5C E3 8D
Nov 27 04:08:25.521: RADIUS: User-Name [1] 8 "uuuuuuu"
Nov 27 04:08:25.521: RADIUS: Framed-MTU [12] 6 1400
Nov 27 04:08:25.521: RADIUS: Called-Station-Id [30] 16 "0040.9645.d18f"
Nov 27 04:08:25.521: RADIUS: Calling-Station-Id [31] 16 "000a.f44a.4dac"
Nov 27 04:08:25.525: RADIUS: Message-Authenticato[80] 18 *
Nov 27 04:08:25.525: RADIUS: EAP-Message [79] 13
Nov 27 04:08:25.525: RADIUS: 02 02 00 0B 01 70 69 65 72 72 65
[?????uuuuuuu]
Nov 27 04:08:25.525: RADIUS: NAS-Port-Type [61] 6 802.11 wireless
[19]
Nov 27 04:08:25.525: RADIUS: NAS-Port [5] 6 326
Nov 27 04:08:25.529: RADIUS: Service-Type [6] 6 Framed
[2]
Nov 27 04:08:25.529: RADIUS: NAS-IP-Address [4] 6 192.168.1.20
Nov 27 04:08:25.529: RADIUS: Nas-Identifier [32] 6 "ap"
12-05-2003 06:40 PM
Well, I was able to use LEAP with the local RADIUS authentication and mandatory dynamic WEP. However, I was not successful in migrating this working solution to WPA.
Here is what I did. Maybe someone will find my error?
1) In the GUI, encryption manager, choose cipher suite of TKIP WEP128
2) clear the WEP key 1 and choose transmit key 2 leaving the actual key blank
3) clear network EAP and enable open auth with EAP in SSID manager
4) Enable mandatory WPA
5) Updated ACU 6.2 on Win XP on client to "LEAP (WPA)"
6) Reauthenticated ... which timed out on first step.
12-09-2003 07:35 AM
I believe the AP uses ports 1812 for Auth
Dave S.
12-09-2003 01:31 PM
Yes, that was the problem. I had left the defaults of 1645/1646 in the config. When I changed them to 1812/1813, LEAP started working.
WPA is what I am having a problem with right now.
12-15-2003 11:56 AM
Well, I opened a TAC Case. It looks like WPA with LEAP may require a "real" RADIUS server like ACS instead of the local AP authenticator. I am still waiting to hear back from the engineer working on my case.
12-16-2003 06:58 PM
LEAP with WPA -DOES- work ok with local RADIUS authenticator. I was using the wrong Cipher... the only Cipher that works in this situation is TKIP.
