licensing requirements for WLC 5520
ziamcaccna
I have a WLC 5520. it is showing AP count license as evaluation and ap count(adder) as permanent but inactive.  I have 100 ap license. i tried updating the license from GUI and CLI and accepted the agreement. but still the license is showing as evaluation. Please help
@ziamcaccna wrote:
(Cisco Controller) >show license summary
    License state: Inactive, Not-In-Use
                                               RTU License Count: 100
This tells me the unit has a 100 AP license but isn't activated (maybe the EULA wasn't accepted).
12 Replies 12
Leo Laohoo
Post the complete output to the command "sh license summary".
    Feature name: ap_count
    License type: Evaluation
     License Eula: Accepted
                                       Evaluation total period: 12 weeks 6 days
    License state: Active, In-use
                                         RTU License Count: 1500
    Feature name: ap_count (adder)
    License type: Permanent
Ah ok, the wrong one is active.
I don't know how to switch on console, but in the web interface go to the Software Activation -> Licenses and click on 'ap_count (adder)' and at the bottom select Activate. Click on Set Status and it should get activated.
AP_Count (adder) is not showing any option to activate it.
i did. when i added it using gui it asked me to reboot also to  accept EULA and i did both.
From cli also it asked me to accept the EULA and i did. not sure why it is not getting activated.
patoberli
You probably have the new RTU license system.
Login to your WLC to the webinterface, go to Management -> Software Activation -> License Type and set it to RTU. Then under Software Activation -> Licenses add the 100 licenses, if you haven't already. Not sure if it requires a reboot at some point.
You should now have lines stating:
License Type Time(expires) RTU Count Status
ap_count Evaluation 12 weeks, 5 days 1500 Inactive
ap_count (adder) Permanent No Expiry 100 Active, In-use
i tried this as well as from cli. but getting as per attached screen shot.
No idea now :(
Try to save the configuration and reboot once again.
What happens if you enter this on the CLI:
license activate feature ap_count (adder)
and if that produced an error, try
Source https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/KVM/b_CUWN8-1-vWLC-Deployment-Guide-using-LinuxKVM/rtu_licensing.pdf
Thank you All for your time.
Disabling evaluation license and then tried enabling ap_count (adder) resolved the issue.
Thanks for providing an update. Did this action cause any outage?
Reboot the controller to remedy the issue.
