light weight AP issue functioning
lenkasurat
Level 3
Level 3
Hello Experts,
I am facing 2 issues at site, kindly find the questions as below.
We have deployed 5508 controller with version - 7.6.130.0
Q1. AIR-LAP1142N-N-K9, as AP get restart the configuration get wiped I have to reconfigure again and again. Any solution or observations?
Q2. AIR-CAP1602I-A-K9 is being deployed in Canada region I checked in the regulatory compliance seems good, however, Radio 1 gets down frequently could not understand Radio 0 works fine but Radio 1 always creates problem. Any solution for the same? kindly find the status it shows for Radio 1
Radio slot#1
Radio Interface Type# 802.11a/n
Admin Status # Enable
Oper Status # DOWN
Regulatory Domain # Not supported
Thank you for all your views in advance!!
Rasika Nayanajith
Does this AP in FlexConnect mode ? What configuration you have to do on AP ?
If it is in local mode, no configuration required on AP as AP never save configuration on it. everything push from WLC.
AIR-CAP1602I-A-K9 is being deployed in Canada region I checked in the regulatory compliance seems good.
Post "show sysinfo" from the WLC & "show version" from the AP CLI
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
Thanks for the response & suggestions.
Q1. I am using AIR-LAP1142N-N-K9 as Flex connect mode, As in other regions if, the AP restarts I don't have to reconfigure it, but I see if this region AP get restarted the AP required to be configured again and here we have only 1 ap for testing only.
Q2. I have attached the WLC sysinfo & AP version
Thanks in advance!
