Lightweight AP in a different VLAN switch is not connecting with WLC
captainmajid
See attached file for details
13 Replies 13
Scott Fella
Well one thing to try id you are not useing option 43 or DNS to help the LAP join the WLC is to place the AP in the VLAN 30 subnet and let the ap join. Then tag the port for vlan 50 and reboot the LAP. That should work for you unless the vlan from the switch the ap is connected to isn't forwarding to the core.
-Scott
which port to tag ?
ap-manager or management interface
Leo Laohoo
Does the AP have an IP Address? If yes, can the AP ping the management interface of the WLC? If yes, then type this command from the AP:
lwapp ap controller ip add
Hope this helps.
When we are typing this command on AP it is showing that command is disabled, so how can we enable command writing mode in lightweight AP.
The command should be enabled in priviledge mode (not in configuration/global).
configure a username and password from the wlc cli:
config ap username password all
-Scott
I have joined the VLAN 50 AP to controller with this command and have connect the wireless client, but the wireless client of VLAN 50 (static IP's)not ping the gateway address i.e. 10.0.50.1, what should I do now ? whereas the wireless clients of VLAN 30 (DHCP based IP's)are working perfectly.
Double check that your dhcp scope is active and that the switches are forwarding the vlan 50 to the L3 switch/router. Post your show run-config if you are still having issues.
-Scott
we are typing this command in privilege mode but it is showing the error that command is disabled, so what to do?
Have you got the possibility to send a screen dump of the console when the LAP is coming up after a reboot? which method are you using to discover your LAPs?
Whoopsie! The command is indeed disable if the IOS you are running is NOT the RCV image. Can you boot into the RCV image and run the command?
OK, I have done this, there was some VLAN segmentation problem.
Thanks for your input
