Anchor Guest 3.2.171.6 Web Authentication page issue
BeechLiam
Hi folks,
I'm having issues with our Anchor controller here running 3.2.171.6. Using a chain certificate for our Web authentication re-direct Page to a WEB-server. sometimes the Guest Clients are not re-directed to the WEb authentication page. After I reboot the Anchor this resolves the issue. I need to use this code to support the ipsec vpn module. any ideas would be appreciated.
Stephen Rodriguez
you need to try to find a non-chained certificate. I know that most CA do not use these anymore, but need to find one. WLC does not support chained-certificate until 5.2. It may work, but it is not supported.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
RapidSSL offers root CA certs which you can use and load onto the wlc to avoid the certificate error issue.
-Scott
My mistake guys , this is in fact a root CA. Wondering if anyone can point me to a bug code that might explain this issue.
