08-14-2009 01:20 AM - edited 07-03-2021 05:56 PM
I built a test environment with 2 APs (1142 and 1252) and 2 4402 WLCs.
I configured them for failover.
The APs join the 1st one and work fine.
After a couple of simulated fails (cable disconnects) though, the APs cannot join any of the WLCs any more.
I get the following error at the APs:
*Aug 14 10:26:10.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:2013 Max retransmission count reached!
*Aug 14 10:26:10.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for 192.168.33.22 is reached.
Does anyone know what could cause this?
After I reboot the APs, they work fine again.
Solved! Go to Solution.
11-30-2009 03:18 AM
Good research man! A little about CAPWAP though. CAPWAP on the 4400, 2100, WiSM, 3750, and ISR series controllers replace LWAPP as the encrypted transport for the AP management traffic only. This is achieved in a DTLS tunnel. All client traffic is still sent in the clear. With a 5500 series controller ALL traffic is sent in the DTLS tunnel. This includes AP management and client traffic and is the most powerful form of CAPWAP security but also the most processor and memory intensive and as such is the reason that the 5508 only can at this time support it. The 5508 can be set to perform just like an older series controller and thus reduce the hardware resources load on the controller as an option. This is generally how I configure the controller as I don't worry too much unless I am in a very secure environment about traffic on the copper cables. I assume that a good IPS box exists on the physical plant to protect incursions.
As for your rating your own post, I know this is a big problem with this new format. Just pick the answer that makes you the happiest of all and the post will show as solved. When a viewer researches your problem they will still show it as solved.
08-14-2009 08:17 PM
What firmware are the WLCs running?
How did you enter the High Availability information of the controllers? Per AP or globally?
Console into the APs that are not working and in enable mode, enter the command sh config ap general. Under the Primary/Secondary controllers what are the details?
08-16-2009 11:02 PM
Firmware: 6.0.182.0 (ED)
How availability settings are set on the APs. Primary Controller and Secondary Controller both the same on both APs.
Both controllers are set on the same mobility group and they "see" each other as "Up" from the web interface.
Let me explain the problem better:
After a couple of times of unplugging the network cables of the primary controller so that I force the APs to join the secondary, the APs cannot join any controller any more.
Debugging shows:
1. APs send discovery messages.
2. The messages are received by the WLCs
3. WLC send response
4. APs receive response
5. APs try to connect via CAPWAP to the correct AP manager (there is only one) IP address and then they fail and I get the error messages shown above.
I should note that both the WLC connect to the network via 2 Gigabit Ethernet interfaces with Link aggregation (LAG). I have already configured the switch for src-dest-ip load-balancing as recommended by the configuration guides.
08-16-2009 11:08 PM
6.0.184 will have the fix for : CSCta09996
08-16-2009 07:27 AM
Just wondering, do you have the mobility groups set on the controllers?
08-16-2009 02:46 PM
You are most likely running into bug : CSCta09996
Problem summary of this defect:
When Backup port become active caused by primary port down, then some LAPs fails to associate to WLC.
4.2.176 code of WLC is not affected.
5.2 code is affected by this defect.
08-16-2009 11:07 PM
It could be related but in my case none of the Access Points ever connect to any of the 2 WLCs. Only a reboot of the LAP fixes the problem.
08-17-2009 01:27 AM
Btw, I thought DTLS was an encryption protocol for encrypting the communication between LAP and WLC.
But as far as I know it is only supported at the 5508 WLC and not at the 4402, which is the one I use.
Could it be a bug that the APs try to use encryption while the WLC doesn't support it?>
11-27-2009 01:01 AM
The problem was solved by using DHCP instead of static IP and static WLC IPs.
It is also a known bug by Cisco.
PS: I cannot choose my own answer as a correct answer to the thread, so the thread remains "Not answered". Perhaps this is sth that the admins should look at.
11-30-2009 03:18 AM
