Low RSSI Client
nir wittenberg
Frequent Visitor
Frequent Visitor
I am seeing APs health being impacted by Low RSSI Client. See screen shot.
What is causing that? Is that a client leaving the campus? Or moving in to the elevator or stairwell?
image.png?
2 Accepted Solutions
joey.debra
Meraki Community All-Star
RSSI is the received signal strength indicator.
A client that is at or past the edge of the designed coverage cel will have a low RSSI (-72 or below).
Since bumping up the power on the access point will only provide further reach downstream, your client will not be able to send back at a higher power since that device is usually limited by it's capabilities. So this means you probably are having coverage holes and need to measure this in a site survey to resolve.
Philip D'Ath
A general tip, go to "RF Profiles":
https://documentation.meraki.com/Wireless/Operate_and_Maintain/User_Guides/Radio_Settings/RF_Profiles
Create a new profile. The most common one I use is "Open Office Profile".
This uses sensible settings. Apply this profile to all your APs.
On the RRM tab enable "AI channel planning" and "Busy hour".
RWelch-USA
Normally an indication of a client being further away from the AP. Dense building materials could factor into that equation a bit too.
joey.debra
Philip D'Ath
