LWAP CLI Command Reference
JASON SIMMONS
Level 5
Level 5
Is there a command reference for cli commands that can be used on LWAPs?
or is there a reference of useful troubleshooting commands?
I tried to find a  cli command that would tell me which controller the LWAP was connected to.
Scott Fella
show capwap client rcb
Example:
AIR-CAP3602E-A-K9#show capwap client rcb
AdminState                  :  ADMIN_ENABLED
SwVer                       :  7.6.100.4
NumFilledSlots              :  2
MwarName                    :  WLC2504
MwarApMgrIp                 :  192.168.201.24
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Rasika Nayanajith
Hi Jason,
There is no seperate CLI command reference for LWAPs, all commands documented under WLC command reference guides. Here is the URL for command referece for most of WLC software versions.
http://www.cisco.com/c/en/us/support/wireless/5500-series-wireless-controllers/products-command-reference-list.html
If you look at any command starting with "show capwap x " those are for LWAPs. There are other commands as well. If you type "show ?" on a AP CLI you will get the full list.
You can use "show capwap client config" to get an AP registered WLC information as well. See below
LAP2#show capwap client config
configMagicMark         0xF1E2D3C4
chkSumV2                61764
chkSumV1                42483
swVer                   7.0.116.0
adminState              ADMIN_ENABLED(1)
name                    LAP2
location                ASW2-G0/2
group name
mwarName                WLC2
mwarIPAddress           192.168.20.22
mwarName
mwarIPAddress           0.0.0.0
mwarName
ssh status              Disabled
Telnet status           Disabled
numOfSlots              2
spamRebootOnAssert      1
spamStatTimer           180
randSeed                0xC710
transport               SPAM_TRANSPORT_L3(2)
transportCfg            SPAM_TRANSPORT_DEFAULT(0)
initialisation          SPAM_PRODUCTION_DISCOVERY(1)
--More--
Rasika
**** Pls rate all useful responses ****
Naveen Kumar
Level 7
Level 7
