WLC different ssid same vlan
john.wright
Level 6
Level 6
                   Is it possible to configure two different ssid's on the same vlan with a WLC?
Sandeep Choudhary
Yes you can map multiple ssid to a vlan.
But remember you can not map multiple VLAN's to an SSID.
Dont forget to rate helpful posts
Sandeep Choudhary
You can map multiple VLAN to SSID with the use of interface groups.
