LWAP Rogue Detector AP - alerting
cchandler63
Has anyone figured out a way to get an AP set in Rogue Detector mode to stop alerting radio down/assoc/disassoc. The radio is down I understand but if you leave an AP in RD mode to monitor wired traffic you are going to get a flood of alerts...
Using v4.2.176. Thanks,
George Stefanick
You can change the sigs under
Security-> Wireless Protection Policys-> Standard Sigs -> Click on the number to change
I hope this helps
Leo Laohoo
In addition to George's post, try this:
Management > SNMP > Trap Controls
Go to the Client Tab for the Association and go the the AP Tab for the Radios.
Hope this helps.
