LWAPP client data rates
david.kelsen
Level 3
Level 3
How can I see what data rate a client is connected at in our LWAPP environment?
If I click on 'Client' from the WLC main screen and then click on a client I can access information such as RSSI, SNR etc., but it doesn't display the client's connection data rate, ie., 24Mbps.
Assuming the client is a Cisco 7921G (which they mostly are in our environment), when I web browse to the IP address of the phone, I get all the same information, but still no data rate.
Can someone point me in the right direction?
jeff.kish
Level 11
Level 11
I don't believe that the WLC tracks the data rate. If you find out otherwise, please share!
