lwapp - Command is disabled
ibrydon
Community Member
We have some 1131 lightweight access points which were once registered with a controller which is no longer available. When we issue the command "clear lwapp private-config" The message "ERROR!!! Command is disabled."
This error message indicates that the static configuration commands are locked out because either:
This command was entered while the LAP is registered to a controller.
The LAP was previously registered to a WLC, but the username/password was not changed from the default.
OK both these things apply. The point is how do I clear the AP and start again since I cannot connect it to the controller???
Scott Fella
If you do a show lwapp ip config and the ap is set for DHCP, then you should be able to have that ap join any controllers. If it is set, then I think the only way is to either create a subnet in which that ap will reside and use DNS to stage the ap to a master wlc or convert the ap to IOS and then back to lwapp. I don't know if there is a way with the mode button or not.
-Scott
Rob Huffman
Hi Ian,
What a pain (we have all been down this road and at least we won't forget to enter a username/password again 🙂 I was working with some folks recently who were experiencing this same issue;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&topicID=.ee6e8b8&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cbf883c
Hope this helps!
Rob
HI Guys
I am experiencing the same problem , ibrydon did the steps worked for you ?
Rob I could not locate the previous post as you mentioned above.
Could some one please advice.
Jal
Scott Fella
Try this link.
https://supportforums.cisco.com/thread/328812
-Scott
