LWAPP protocoll doesn?t work
i have one wlc 4402 controller and ap 1020 accesspoint after configuration the switch cann?t associate the ap?s. so what can i do. i have configured layer 2 with an internal dhcp server and so on.
Thank?s in advance.
Kind regards
Michael
10 Replies 10
Stephen Rodriguez
Michael,
Is the port the AP is plugged into an access port, and accessing the VLAN the management interface is in?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
yes. i think it is allright
i follow the discribtion in the guide.
frankzehrer
Level 4
Level 4
Hi Michael,
are the APs and the WLC in the same regularoty domains?
What kind of code does the AP provide?
If you have ordered an AIR-AP1020-R-K9 the R in the number shows up the country code.
If the country code of the WLC and the attached APs differ they will not be attached.
Best regards,
Frank
Hi Frank,
thank you for your responce.
I have AIR-AP1020-E-K9 Accesspoint.
The ap?s and the switch are on the same switch.
no domain.
country code: de
Best Regards
Michael
Have you set the time on the WLC ?
thank you chris for your answer
yes i set the time.
must i have an ntp server?
i could?nt ping the management port.
so what could happened.
thanks in advance
michael
Hi Michael,
the management port is only reacheable for the APs with the LWAPP. ICMP is not allowed.
The Management interface and the APs are in the same LAN Segment (VLAN) and subnet?
Is between the APs and WLC any Firewall, ACL or proxy?
Can you provide us with some more information:
- The output from "Management -> Logs -> Message Log"
- And maybe some more information like the VLAN Assingment, why you have choosen the Layer 2 Option.
Have a look here for the Layer 2 deployment:
http://www.cisco.com/en/US/products/ps6366/prod_technical_reference09186a00806cfa96.html#wp1050339
Best regards,
Frank
The management interface will respong to ICMP requests. It is also the only supported means for direct connection to the controller for administration, ie http/https, ssh/telnet and SNMP.
If you could post a text copy of the config, less all the AP information, this will help us to be able to figure out why you can't reach it.
HTH,
Steve
Dear Frank,
the management port and the ap?s are in the same subnet, no firewall, now access controll list, no proxy.
Must i have a distribution port?
Does the controller only communicate with the ap over the distribution port?
Becaus i cann?t ping the management port, will that be the reaseon.
Kind regards
Michael
Hi Michael,
Better you give us some input from teh console port:
show run-config
Best reagrds,
Frank
