MAC filtering on wireless
Colin Higgins
Level 7
Level 7
I am building out a new network to replace an existing wireless network that used MAC filtering for clients. The old setup consisted of a pre-shared key and MAC list.
I see that in dashboard, you can go to organization-->clients and add a client to the network, but after I put in the MAC and a name, and hit save, it simply says "changes saved" --I don't see that MAC listed anywhere. Will it not show up until the client actually connects?
Also, to do MAC filtering do I have to use a Radius server? Or can I use the old pre-shared key with MAC filtering?
Philip D'Ath
Meraki Community All-Star
MAC addresses you add as clients don't show up until the client has connected, and then you have to display the list of clients for the time period the client would have been connected in.
Within the scope of the question you have asked, @kYutobi has given an excellent answer. Basically create a layer 3 firewall rule blocking all traffic, and then create a group policy and attach it to each individual client that overrides the firewall rules allowing the traffic for that one client.
HOWEVER, this is not a modern way of doing things. You should really consider using something like WPA2-Enterprise mode or at a minimum WPA2-PSK (with this last option being very simple to implement).
You could also consider using the "Trusted Access" feature of Systems Manager (although this does require you to buy Systems Manager licences). This uses certificate based authentication - but frees you from having to manage the certificates.
https://documentation.meraki.com/zGeneral_Administration/Cross-Platform_Content/Trusted_Access_for_Secure_Wireless_Connectivity
"Trusted Access" is still a little "green" at the moment. Apple support is good. Android and Windows 10 support is weak to poor - but give it maybe another 3 months and that should be sorted out.
12 Replies 12
kYutobi
Level 11
Level 11
You can create a "group policy" that way you have a list of MAC addresses you import plus make your own rules and blocks for that policy. You won't need a RADIUS server.
Enthusiast
I see the group policy creation screen, but don't see anywhere to add a list of MAC addresses
You add them as if you were adding a wireless client. Select the dropdown and assign policy.
Enthusiast
I configured an SSID with MAC filtering as described here and indeed this works.
But what I have noticed is that if I have a device that its MAC address is not registered in the dashbord
By just having the password, this device connects and obtains an IP but it has no access to the Internet because the MAC is not registered. This device will have access to the Internet until the MAC address is registered in the Dashbord.
I have made several L3 rules conventions but I have tried to ensure that my computers do not have IP.
Is there a way to avoid what I'm talking about. ???
Note: The addressing is being given by Meraki.
Hi ,
Please let me know the steps for configuration
Philip D'Ath
I have the SSID and MAC working (assigned a policy to my laptop), but I am a little unclear on the firewall blocking
so I should go into the SSID and select layer 3 firewall rules and set the default action to block any to local LAN (or any) and simply leave it as that?
wouldn't this block access to everything regardless of allowed MACs? Or does the individual group policy override that?
@Colin Higgins The group policy will override it but by default it will block everything else that's doesn't have one.
Enthusiast
yes, it looks like it is working. Unless the client is listed with a MAC association and policy, they get "packet filtered" errors when trying to do anything on the network--so it looks like they are blocked.
thanks for your help. This was a bit counter-intuitive, but now it makes sense
Sandra Linares
Hello!
In a network that only has an MS120-8FP switch and 2 MR46 APs installed, would it be possible to use a group policy to perform MAC filtering? I have tried it but I have not been able to get it to work, the devices connected and browsed the same whether they had the group policy applied or not.
Philip D'Ath
Yes, but you can also simply limit access based on MAC address. You don't provide enough info to really help you, but for WiFi you could use iPSK:
https://documentation.meraki.com/MR/Encryption_and_Authentication/IPSK_Authentication_without_RADIUS
For wired clients you could use a sticky MAC address.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Switch_Ports
The clients are wireless and I want to filter the clients by their MAC. But I don't have installed a MX device, only have a switch and I only can configure a Deny Rule in Wireless -> Firewall&Traffic Shaping to apply a group policy but I'm not sure if it is going to work.
Thanks!
