Machine Certificate + VWLC + RADIUS
jspobuk
Frequent Visitor
Frequent Visitor
Looking for a very high level explanation.  I am trying to accomplish:
Tablet wirelessly connecting to existing RADIUS through VWLC
I need the certificate to be machine based, not user based.  I think.  I know the tablet needs to connect automatically without prompting for a user name and password.
I am using WPA2 Enterprise Security
I am looking for direction on how to generate the necessary certificates so that the tablet is authenticated by the RADIUS server when connected.
What certificate template do I use?
Do I generate the certificates through the VWLC?
Where do I store the certificates?  Does it have to be on VWLC and tablet?  Or just tablet?
Thank you,
John
ammahend
as others mentioned you need a PKI infrastructure.
workstation authentication template, when you go to manage template
No, vWLC is not a certificate authority.
the client cert will be stored on client machine, server certificate will be on your Radius server, they both also need certificate authority root certificate to trust each other.
See this video it might help.
https://youtu.be/SgAjEuCAFzE
Hope this helps
-hope this helps-
johnd2310
Level 11
Level 11
HI,
What radius server are you using, Cisco ISE or  Microsoft NPS?
The following doc should explain certificate  based authentication and how to configure it.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/213543-configure-eap-tls-flow-with-ise.html
John
**Please rate posts you find helpful**
Thank you for the quick response. We are using Microsoft NPS.
You will need to configure your Microsoft infrastructure to support certificate  authentication. Check the following docs:
https://docs.microsoft.com/en-us/windows-server/networking/core-network-guide/cncg/server-certs/deploy-server-certificates-for-802.1x-wired-and-wireless-deployments
Use the doc i previously attached for the cisco Wireless controller configuration.
John
ammahend
Hope this helps
-hope this helps-
