Wireless controller 5508
bewome
Community Member
My wireless controller is 5508 and I am unable to access the controller from the latest browsers. But I can access it from an old version of Mozilla Firefox browser.
Leo Laohoo
I do not even want to ask "what firmware the controller is running on" because I am sure it is very old.
Either upgrade the firmware or continue using old web browser.
Leo Laohoo
johnd2310
Level 11
Level 11
Yes, you are probably running old software version on the controller which is using old tls version. You can upgrade the code on the controller to the latest version. If you need to maintain the current code on the controller,then you will have to  use a browser that supports weak cipher. You could also try another browser like chrome. I have found chrome sometimes works for wireless controllers running old code.
John
**Please rate posts you find helpful**
