02-17-2007 02:17 AM - edited 07-03-2021 01:38 PM
can anybody tell me what the max noise threshold is for a VoWLAN deployment
thx
Solved! Go to Solution.
02-18-2007 06:23 PM
For Vocera deployment the badge should have at least -65 dBm RSSI and SNR should be above 25. Refer to Vocera deplyment in Cisco Unified Wireless Network Infrastructure document at http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080766d54.shtml#c5
More information at http://www.vocera.com/downloads/InfrastructureGuide.pdf
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806d11cb.shtml
Basically you have to ask your VoIP wireless phone vendor for signal related requirements.
02-18-2007 06:23 PM
