Maximum number of MACs
Patrick McHenry
Level 4
Level 4
I tried to add some more MACs to our Controllers through the WCS. I hate mac-filtering. We plan on stopping sometime. Three of the Controllers(4402s) are reporting that we have reached the max which appears to be 506.
First, is there anyway to increase this number?
Second, if not, does anybody have any ideas/experience with deleting clients? Should I use reporting to find MACs that haven't been used for sometime and delete them? Is there a better way?
Thanks, Pat.
2 Accepted Solutions
Surendra BG
ANS - No there is no way we can increase it on the WLC.. however we can use ACS to save the the MAC instead of WLC.
ANS - The one that you have mentioned is the better way.. i dont think there is one whic is better than that!!
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
If we have cisco ACS.. we can do the MAC filtering and the MAC will be on the ACS not on the WLC>. here is the link to do the same..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml
Surendra
Surendra BG
7 Replies 7
Surendra BG
Surendra
Surendra BG
I don't understand your suggestion:
"ANS - No there is no way we can increase it on the WLC.. however we can use ACS to save the the MAC instead of WLC."
How would I use the ACS? Can I MAC-filter using the TACACS server? Or are you hinting dot1x?
Surendra
Surendra BG
Surendra,
Do I have to disable the mac-filtering from the controller? I've have followed the instructions for using the ACS for mac-filtering but, it won't allow clients to connect if I configure them only on the ACS.
Either we can use WLC database or ACS.. there is no need to configure them on both.. please follow the step by step process from the below link..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml#c3
lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surendra,
It's not working for me. I followed the instructions but, it is not working. I was wondering if I have to check - Allow AAA Override? But, I would think that if I checked this, it would disassociate all users that were only in the WLC mac-filter database? Don't really know.
Thanks, Pat.
AAA override is for Dynamic VLAN assignment.. I have this set up in my lab and it just works awesome!!
Surendra
Surendra BG
