mDNS not enabling on all APs
joeclarktx
I'm attempting to enable mDNS on 6 APs.  I have enabled on the controller and the SSID, but two of the APs are showing a disabled status. is there some way to force the APs to enable mDNS?
Controller: 3504
Code: 8.10.162.0
APs: 9120
9 Replies 9
marce1000
 - Do you mean the ap is disabled 'completely'.      mdns is part of the controller configuration. You may provide screenshot for clarity.
 M.
joeclarktx
I can provide more details, but this is what i see on the controller
Just re-read your comment, the APs are enabled, just the mDNS is showing disabled on 2 of the 6 APs
        - Reboot those ap's , check if that can help.
 M.
I tried rebooting, didn't change anything. Also tried clearing the config, with no success.
         - So the 6 ap's are all 9120 ?
 M.
Of the 6 APs,
3 are 3802s, these are all ENABLED.
the other three, 1 is ENABLED, but the other two are DISABLED
 - For the time being I  don't have anything more specific but always useful is a checkup of  the controller-configuration with : https://cway.cisco.com/tools/WirelessAnalyzer/
 M.
Thank you, i'll try it
