mesh between 1552 and 1572 model
kknguyen99
We are currently using 1552E model since this is obsolete, we are looking at 1570.
Would these two mesh together?
Reading the manual and deployment guide it appears they do but I wanted to check to make sure.
Sandeep Choudhary
Yes they do.
*** Just check the sw version need to supported on wlc by these APs:
1552 - min sw version dupported 7.0.100.0 and higher
1570 - min sw version supported 8.0.100.0 and higher
Don't forget to rate helpful posts
mohanak
Yes, it supports. Be on version 8.0.100.0 or above.
