Cisco 1602e Antenna question
tringwelski_2
Hi, im looking for a recommendation for antennas for a pair of 1602e aps bridging outdoor with 500 ft between them.
thanks
Mark Sparling
Level 4
Level 4
The 1602e isn't outdoor rated APs, but the antenna you would want to use for bridging and you have line of sight would be AIR-ANT2566P4W-R Qty1 per AP.  Please remember the antennas need to be hight enough so you don't zap people in the head. Please refer to - http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1600/quick/guide/ap1600getstart.pdf
AIR-ANT2566P4W-R - http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.html
mohanak
1600 series access points are intended for indoor.
External Antenna Options and Patterns
AP 1600/2600 and AP 3600e
The following dual-band, dual-resonant antennas are available for use with the AP 1600e*/2600e and the AP 3600e:
AIR-ANT2524DB-R – Dual-band (Black) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2524DW-R – Dual-band (White) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2524DG-R – Dual-band (Grey) dipole (4 required) – 2/4 dBi Dipole
AIR-ANT2524V4C-R – Dual-band Omni-directional (1 required) – 2/4 dBi Ceiling mount Omni use
AIR-ANT2544V4M-R – Dual-band Omni-directional (1 required) – 4/4 dBi Wall mount Omni use
AIR-ANT2566P4W-R – Dual band directional (1 required) – 6 dBi Patch wall mount use
NoteThe AP 1600 requires only three dipole antennas, not four. For ceiling, wall or patch mounts, simply leave the fourth antenna lead unused.
