mesh firmware Cisco AIR-CAP2602I-E-K9.
cbettont
hello,
we have a couple of access point Cisco AIR-CAP2602I-E-K9 that are configured as lighweight access point.
can we convert these access point to mesh firmware ?
We need to configure these access point in Bridge mode as RAP or mesh access points as MAP
 is it possible ?
kind regards,
Cristiano
Good to hear that you are able to solve the issue
Please mark this discussion as correct answered.
PETER MOOREY
If the AP is already in lightweight mode (connected to a WLC) you can change the mode to 'Bridge' which is effectively mesh mode, and then set up the AP as a RAP or MAP.
There isn't a 'Mesh' firmware, the options are either lightweight or autonomous.  Mesh is only available using a WLC and therefore lightweight AP software.
Hope this helps,
Pete.
Document is a bit aged but lots of information is till the same
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-mesh/111451-indoor-mesh-deploy-guide-00.html
thank you for your feedback. I was able to reconfigure my access-point as mesh
kind regards,
