Mesh Wireless Verification Help
WGL_BK
Level 3
Level 3
We have two AIR-AP1562I-B-K9 APs forming a wireless bridge between two offices. This functioned normally until today. Is there any command that we can run at the Root AP to confirm whether or not it's seeing CAPWAP discovery traffic from the Mesh AP?
The mesh AP is currently unable to get to the gateway but that's only available via the wireless bridge that it's supposed to be forming. Wireless isn't my forte really so any help would be greatly appreciated.
show mesh status
Mesh Status: Enabled
Running as: Mesh AP
AP is in: Abandoned Mode
Gateway is:  NOT REACHABLE
Uplink Not Valid
Distance Vector Info:
Hops to root: 0
Ease to root: 0
Mesh Capwap Status:
Link State   :Discovery
State        :CAPWAP_DISCOVERY
Standalone   :False
Joined Once  :False
Skip Cleanup :True
Path Control Registration status
Role Reg-State Clock-Ticks
Root      ROOT         111
patoberli
Have you tried rebooting both?
You might want to save the configuration first, in case that hasn't been done since setup.
For debugging capwap, try "debug capwap ?". I don't have a mesh setup, so I can't test.
patoberli
Thank you for your quick reply. I've been trying to avoid rebooting both in hopes of getting an understanding of the issue(s) behind the failure. I will try to run that debug command at the Root AP to see if it offers any insight and then try a reboot of the RAP. I've already rebooted the MAP multiple times.
Rebooting the RAP fixed it, and I have no idea why. Thanks.
Could be a software bug. If it happens regularly, then I would suggest to upgrade to a newer software version.
