Workgroup Bridge Mode vs Standard Bridge Mode (APs)
AndrewGibbons8
Could someone please concisely explain to me the difference between the standard Bridge Mode on an AP and Workgroup Bridge Mode?
Thanks in advance,
Andy
Rasika Nayanajith
WGB is used to connect wired only devices onto wireless network. Wired device will connect to Ethernet port of WGB & use WGB's wireless interface to connect to a given wireless network (SSID). It is common in moving environment (POS terminals, Cart on Wheels, Forklifts, mining trucks,etc)
Here are some examples of WGB configurations
1. https://mrncciew.com/2013/07/02/wgb-config-example/
2. https://mrncciew.com/2013/06/13/wgb-with-psk/
3. https://mrncciew.com/2013/04/30/wgb-with-capwap/
4. https://mrncciew.com/2014/01/04/wireless-wired-clients-behind-wgb/
5. https://mrncciew.com/2013/06/16/ios-ap-wgb-with-multiple-vlan/
6. https://mrncciew.com/2013/06/16/unified-ap-wgb-with-multiple-vlan/
7. https://mrncciew.com/2018/05/25/wgb-with-peap/
8. https://mrncciew.com/2013/04/28/wgb-with-eap-fast/
9. https://mrncciew.com/2013/07/24/wgb-roaming-part-1/
Standard bridge (Root Bridge/Non Root Bridge) is like a trunk port between two switches to carry multiple vlans. Here are some reference post from my blog.
1. https://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
Rasika
*** Pls rate all useful responses ***
Scott Fella
Bridge mode is for backhaul connection, like point to point or point to multi-point. WGB is when you have clients connected to an ap acting as a WGB and that device connected via a wireless connection to an access point.
-Scott
Rasika Nayanajith
Rasika
Thanks to both of you for the quick responses! I appreciate it!
