Mobility Express 8.6.101: Connection failure: 60, Peer certificate cannot be authenticated with given CA certificates
Blitter
When trying to check for new software update from "Management/Software Update/Check Now button" or from the Down arrow icon, Il get an "Connection failure: 60, Peer certificate cannot be authenticated with given CA certificates" error.
Transfer Mode sets to Cisco.com
Cisco Username is set and correct
Cisco Password is set and correct
A private CA and private cert were uploaded to the aironet master APs (running ME 8.6.101) for management reason.
Any information ?
Olivier
6 Replies 6
Rasika Nayanajith
Do you have smartnet service for that Master AP. As per the documentation, without that upgrade process will not initiate. See below
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-4/b_cisco_mobility_express_8_4/b_cisco_mobility_express_8_4_chapter_0111.html#task_DC321B504E9545F4B9201BB29EF5D8BB
  • EULA acceptance on a per user basis. Only Master AP (not all APs in the network) must have SMARTNet contract else Software Update will not start
Rasika
*** Pls rate all useful responses ***
Maurice_
This is a known bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh32031
Should be fixed in 8.7.102.0 (available now).
If i can not download the software directly from Cisco.com in management/software update, do you know if i can upgrade from 8.3.121.0 to 8.7.102.0 directly or i have to upgrade step by step ?
Thanks for your return.
The documentation currently lacks this information, but I think that's a documentation failure, because Cisco normally exactly states it. So I assume it should work.
But honestly, I wouldn't go to 8.7, unless it contains a feature you absolutely require. If not, go for the latest 8.5MR3 beta, which you can find in this forum.
patoberli
I suggest, if compatible with your AP model, to use 8.10.185.0.
Having this issue with version 8.10.171.0
