modeling amount and location of access points in Cisco Prime
Andrey128
I've imported into Prime infrastructure a floor map, next I need to do a simulation and get approximate amount of access points and their locations
I cannot find correct steps, maybe someone could share details.
thanks a lot
I believe what you are looking for is here..
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/3-0/user/guide/pi_ug/wireless-maps.html
Check out the "Using the Map Editor" Section.
HTH,
William Kuczmera
